Finally got to dyno my IX !
Old Jan 11, 2007 | 06:26 PM
  #31
Warrtalon's Avatar
Originally Posted by kouzman
At THE SHOP that they have a dyno dynamics they told us that the difference from a dynojet is 1.12. Multiply your numbers to 1.12 and you will see what you would have gotten on a dynojet...
292whp/290ft-lbs on a DD is 327/325 on a dynojet...
for the history i made 298.6 whp and 306 ft-lbs on the Shop's DD... so i guess we are pretty close...
It's by no means a direct conversion. Usually, it's closer to 1.15, but the DD at the Shop already reads just like a Dynojet. Likewise, different Dynojets read differently, and then it also depends on what correction factor is used. It's never wise or useful to try to apply a static correction factor between dynos. THe track tells the real truth.
Old Jan 11, 2007 | 06:36 PM
  #32
kouzman's Avatar
This is my dynorun on the Shop's DD...
According to the guys there with a testpipe it could be maybe over 305awhp...
You should DEF check your flash. I cannot find any other reason to be so low...
Old Jan 11, 2007 | 06:40 PM
  #33
m4tt VIII's Avatar
No, don't use the Greddy Type RS - not sure why people get the Greddy BOVs. Is it just the Greddy name or what?
In my defense it came with the car when i got it lol
Old Jan 11, 2007 | 07:09 PM
  #34
BURNALL_4's Avatar
Dont buy an electronic boost controller!!!!! you'll thank me later (there is to much to go wrong w/ electronics.)
Old Jan 11, 2007 | 08:21 PM
  #35
Warrtalon's Avatar
Kouzman, your graph stops at 6500, which doesn't help us much. Why in the world do they stop so early? It should go to 7500 to show what happens through the entire rpm band...at least 7000 to show what it does after it peaks.
Old Jan 12, 2007 | 06:15 AM
  #36
kouzman's Avatar
to tell you the truth i don't know.... This saturday that i am installing the cams and Al will custom tune the car i will ask them and of course i willl have new dynographs...
I have a couple of runs o a Dynojet, which were made without the fuel pump and on a hotter day. I did 328 on these runs but they go all the way until the 7800rpm rev limit. I will scan them and post them too... On these graphs you can clearly see that the car keeps almost the max power until around 7200rpm and then drops VERY gradually, not like you let go of the gas...
Old Jan 12, 2007 | 09:09 AM
  #37
racerxj17's Avatar
congrats! paul keeps a clean shop and runs it well. my brother also got his evo dynoed there, wartalon stage one. it pulled 298 hp 309 tq. the magic "flash" was so rich the wideband wouldnt even read it. he has someone come do a quick tune on it, and jumped to 315 320 with the afr around 10.8-11.0.
Old Jan 13, 2007 | 01:15 PM
  #38
jordo's Avatar
Originally Posted by er0e
Im just trying to figure out why my IX is not making the power it should be
I compared my dyno sheet to someone elses on SCE. Identical.
Could it be that my I got a "less powerful" IX than others
Are there any signs of knock? those little dips make me think knock is present.
Old Jan 13, 2007 | 03:52 PM
  #39
3SgteGuru's Avatar
Check the numbers out. AMS Turbo back, walbro 255lph Fuel Pump, Greddy Profec b-spec II boost controler 23psi, and a air cone to **** warrtalon off. Turbo Tirx tune.
Old Jan 13, 2007 | 04:42 PM
  #40
Warrtalon's Avatar
YOu guys should tell me when stuff like this happens so that I can remedy the situation. Who is "Paul," and which shop is his? You didn't quote anyone, so I don't know who you're responding to...
Old Jan 13, 2007 | 04:56 PM
  #41
nj1266's Avatar
This was on a dynojet:
Mods are:
Espelir 2.75" dp
3" Ti cat delete
3" Ti Greddy Catback
MBC @ 22lbs
Dr. Grey Tune
I hope with a 3" downpipe, o2 housing, and an electronic boost controller I might be able to squeeze a bit more power.
Any comments/advice would be appreciated
I am sorry to say but these are low numbers for a 9. Your car should be putting around 320 hp even on 91 octane gas. My Evo 8 put down 299 hp with a TBE and a drop-in filter on 91 octane gas.
xBoostx
Aug 30, 2016 05:48 AM
Tmracer22
May 23, 2016 09:57 PM
Speed Element
53
Aug 12, 2008 05:06 PM
inphluence
Dec 2, 2007 12:37 PM
Boost3dxEvO
May 11, 2007 01:23 PM
