XS Engineering Intercooler pipe kit questions
Old Jan 14, 2007 | 06:55 PM
jedibow's Avatar
I installed racemax hard pipe kit on my Evo yesterday and I am experiencing a whine when I reach boost. I was wondering if this is normal or if I should do some troubleshooting. Could I have an airleak?
Thank you for all your help
George
Old Jan 14, 2007 | 06:56 PM
electricevo's Avatar
Are you loosing any boost?
Old Jan 14, 2007 | 07:01 PM
jedibow's Avatar
no it actually increased about a 1psi so I don't think it is a major leak just it sounds like a tea kettle on boil!
Old Jan 14, 2007 | 07:14 PM
jedibow's Avatar
Anybody else? I would like to hear from somebody that has the kit if possible...
Old Jan 15, 2007 | 01:04 AM
sgevotx's Avatar
It's the flange that connecting from the turbo to the lower intercooler piping that is leaking. If it sound like a supercharger whine, that should be the problem. Usually happen when you over tight those bolts and flex the aluminium flage that cause the air leak.
Bring the lower pipe to the machine shop and resurface the flange. Use new gasket and bigger washer for the bolts. That should fix your boost leak.
Old Jan 15, 2007 | 06:32 AM
jedibow's Avatar
It does sound like a supercharger whine but only at part throttle, and also I'm now making more boost than before? The whine happens from 15 to 5 degrees of vacuum once there is boost the sound goes away...
I was wondering could it be the BOV??? I'm still running the stock BOV
Old Jan 15, 2007 | 12:16 PM
matt55's Avatar
I would bet you have a leak , do a boost leak test and come back and tell us what was wrong .
If you dont know how to /dont have a boost leak tester , search for "boost leak tester" and you will find how to build one cheap . They are worth there weight in gold !!
BTW the stock (2003-2004bov) starts leaking @14(ish) psi
Old Jan 16, 2007 | 06:38 AM
jedibow's Avatar
I'm going to do a leak test this weekend and will post the results once I the test is completed again thank you for everyones help!
Old Jan 16, 2007 | 08:07 AM
matt55's Avatar
btw i found that a warmed up motor with #1@tdc works the best for me when doing a leak test....
Old Jan 16, 2007 | 09:34 AM
TURBODAWG's Avatar
Sorry to be off topic but do you have any pictures of the installed intecooler pipes. I would like to see a picture of the Racemax pipes installed. I searched and couldnt find any.
wickedwrich
Jun 17, 2011 09:20 AM
stevolee
149
Jan 26, 2011 07:13 PM
landis507
May 30, 2008 01:18 PM
psphinx81
19
Sep 16, 2007 10:05 AM
Derek888
Jan 26, 2005 07:46 AM
