Bad cam gears?
Old Jan 16, 2007 | 12:38 PM
jusa4cyl's Avatar
Bad cam gears?
I recently removed my cam gear cover to change the cam gears. But when I saw the gears turning one looked like it was out of balance or bent. Does anyone else have this problem or heard of it. What do you think caused this? Its not loose but you can see that it looks like its wobbling a little bit. The car seems to be perfectly fine. And no, no one has recently did a cam shaft change or mess with anything close to it. It must have been like this for a while.
Old Jan 16, 2007 | 01:31 PM
EV0lut10n_8's Avatar
The cam gear seats on the cam shaft. It may not be seated fully giving it the wobble look when its spinning.
Old Jan 16, 2007 | 01:40 PM
jusa4cyl's Avatar
Man i hope so. I guess i need to take off the belt and see if thats the problem. How do think it came unseated?
Old Jan 16, 2007 | 02:19 PM
the bolt holding the cam gear to the cam may not be fully torqued. according to your sig you had the cams done right?
Old Jan 17, 2007 | 05:47 AM
jusa4cyl's Avatar
Yes the cams have been replaced. They were already in the car when I bought it. Thanks for the advice i will check for that.
asu11
Aug 7, 2016 10:53 AM
CBingg
Dec 25, 2015 02:16 AM
evo_q8
Sep 9, 2012 09:56 AM
GBAILEY472
Jan 31, 2011 10:13 AM
justrick
11
Oct 5, 2004 10:54 PM
