The NEW "GT35R" from Buschur Racing..
Old Jan 22, 2007 | 10:09 AM
  #61
Blue Evo 8's Avatar
Did Dave Buschur's account get locked out??? What did he do now?
Old Jan 22, 2007 | 10:16 AM
  #62
redman012's Avatar
i saw that too. i tried to send he a reply, and it said no. I thought he gave me the ban stick for pms lol
Old Jan 22, 2007 | 03:02 PM
  #63
jbrown's Avatar
Originally Posted by jordo
not always, lets say you are almost out of the efficent range of the turbo, boosting 35psi-45psi.. adding the larger housing frees up that "choke"
I have many dyno sheets to proven what Im saying.
Note Dave's astute use of the word "generally" in his post. Doesn't that mean the same thing as "not always"?
And LOL @ a GT-35 turbine being a "choke point".
I'd attribute it more to "hitting the nail on the head" and finding a compressor / turbine combination more in tune with the flow characteristics of an evo engine.
Old Jan 22, 2007 | 05:35 PM
  #64
SubiEvolved's Avatar
interesting find.
I wonder if they can develope a "37R" with this new improved wheel. That would be something i would look into instead of just upgrading my 35r to this one. Price vs performance.
Old Jan 22, 2007 | 07:58 PM
  #65
Jasil's Avatar
do you want to see the dyno graphs?
spool was the same just alot more power through entire powerband.
this isnt the same thing as the full race spec turbo is it?
gt35r turbine/67mm compressor
Let's see some graphs at the same boost. I already know the answer regardless of what you post I just want to see what you post.
Old Jan 26, 2007 | 06:38 PM
  #66
David Buschur's Avatar
Reading should be pressed harder in school these days. That is very apparent everyday I visit this site.
I did say GENERALLY a larger A/R will make the car spool slower. Thanks for reading, or not reading, not sure what is going on anymore.
Bad news on this turbo. Robert wants more testing. We are going to try another change to the turbo and now I need to collect some more data. This may be awhile guys, sorry.
Old Jan 26, 2007 | 06:45 PM
  #67
scheides's Avatar
EvoM Moderator
Gah, you guys and your testing! Why don't you just develop a variable-vane turbine for the 35R and then no one will ***** about high boost threshold again!
Old Feb 7, 2007 | 01:57 PM
  #68
EVO8_PR's Avatar
Originally Posted by davidbuschur
I pulled the car into the shop for testing last week. We finished our fuel system testing on the car. Then I tested a new custom ground camshaft.
To the point. Today we drilled my manifold for back pressure testing on our GT35R turbo kit. I made 3 back to back pulls with the car with no tuning in 3rd gear. Pulls were done from 3,000 to 7,000 rpm. Each pull the throttle was at 100% at 2,000 rpm. After collecting this data we pulled the turbo off the car, cartridge only. Installed the new turbo into the same turbine housing and put the car back on the dyno.
The new turbo is built by Forced Performance, same company building the LT/Green turbo. Forced Performance makes the investment cast stainless steel 02housing we use on all of our cast manifold turbo kits.
The new turbo is called a GT3582HTA.
Bringing this thread back from the dead.
David you never did tell us what your findings were in terms of exhaust backpressure from the turbo swap, and have you measured the stock turbo in order to see how much of a difference there actually is?
And what happened to the cams, I have not heard anymore of them, will they or will they not be available?
Old Feb 7, 2007 | 06:33 PM
  #69
mac_05evo's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=250024
Old Feb 7, 2007 | 07:58 PM
  #70
EVO8_PR's Avatar
If it weren't for my previous post that topic might still have been in David's thoughts instead of here on EVOm. Now what happen with the backpressure logs...
Old Feb 8, 2007 | 02:38 AM
  #71
Evo_7's Avatar
Pics of the New GT35R????
Old Feb 8, 2007 | 07:18 AM
  #72
jbrown's Avatar
Old Feb 8, 2007 | 07:31 AM
  #73
Migsubishi's Avatar
Well it has been sitting here waiting for us to test it and I finally got a full day to finish up this additional testing on my car today.
Brief update. My 2004 EVO RS has every single go fast part on it that we make, everyone. The car has run a best of 9.97 at 142.32 mph on radials in full street trim, driving to and from the track.
Below is the before and after of the testing. The very first pull with the new turbo showed an increase of 3 psi of boost. I had to adjust the boost controller to bring it back down to the same level of the initial test. The first pull was the highest but with the high boost it was not a fair test. The 2nd pull the car was leaner with this new turbo, also not a fair test. After quite a few runs I got the AFR's back to equal that of the original GT3582. That is the chart below. The most impressive part of this is the area under the curve. This turbo makes considerably more power in the midrange than a standard GT35R does. In some places on the graph you can see it is up as much as 50 whp/ft lbs. This is going to make this turbo much more easy to drive on the street.
You will notice that both of the graphs start out exactly even at 3,000 rpm. If you look at the average at the bottom of the page the new GT3582HTA turbo averages 20 ft lbs of torque more and 18 whp more over the entire rpm band. This is major when you consider at 3,000 rpm they are identical and up top they are close again.
Here is the dyno sheet:
Pricing has not yet been determined on this turbo. It is going to add to the cost of our standard GT35R turbo kit. I am waiting for pricing and when I get it I will post it here.
Thanks for reading.
Just curious, The psi that these tests where done at was never disclosed? I'm not sure how to read the bottom of the graph to figure it out....
P.s Great work, your knowlege and willingness to disclose this type of info is always greatly appreaciated
  #74
RSGuy's Avatar
^^^^^ahahahahaha
Old Feb 8, 2007 | 09:58 AM
  #75
Migsubishi's Avatar
^^^^^^ I dont get you, Do you see something I don't? If so it would be nice of you to elaberate...
