AMS 50 Trim or Buschur 20G LT? I'm torn!!
Old Jan 20, 2007 | 02:25 PM
dsm_mikey's Avatar
I have a delima here. I am ready to upgrade my EVO 9. Right now I have 3" Turbo-back exhaust, AMS LICP, Intake, MBC, Walbro 255 and a road tune by Al. When I upgrade the turbo I am going to go with an AMS intercooler, larger injectors and possibly new cams. I have a 9 so I am still torn between the cosworth cams and the new GSC s1 cams. I will not be running race gas. Looking to run 22-24 psi on 93 daily-if possible.
Obviously the AMS 50 trim is much more expensive, but it is an impressive kit and I can see where the extra dollars are. Looking for an impressive daily driver than can hold its own.
Any feedback from any owners of these two turbos would be appreciated. I have a stock internal motor with only the mods listed above. I don't want to spend the extra 2k on the AMS kit if the 20G LT is going to do the same job. Like I said, I understand why the AMS kit is more (beautiful headers, TiAL wastegate, BB Turbo) but if it is similar to the 20G LT I will probably be going with it. Again...any feedback from ACTUAL owners or tuners. I have read most of the posts on both of these turbos and they appear to line up fairly close although variance between dynos have made a direct comparison difficult. It appears the 50 trim has the edge in the numbers war on pump. But a direct comparison would be nice.
I have an EVO 9 with the mods listed in the 1st paragraph.
-MIKE
Old Jan 20, 2007 | 02:37 PM
Frenchy4g63's Avatar
You could also get a 50trim from Buschur too. About $3000.00, and you'de get a dual BB Garrett turbo, and a 44mm TiAL wastegate.
Old Jan 20, 2007 | 02:40 PM
dxbevo9's Avatar
i am not an owner or tuner of any...but i can tell you on a IX...the 50trim is the better option... <--- my opinion
Old Jan 20, 2007 | 02:41 PM
dxbevo9's Avatar
i never knew buschur made a 50 trim...any link?
edit: found it on their website...anyone have info on this kit?
Old Jan 20, 2007 | 02:43 PM
MR. Birdie's Avatar
Or you can consider the 20G-LT, which flow rate is very similar to the 50 trim and sttill have stock spooling charateristic.
Old Jan 20, 2007 | 09:18 PM
dafunk630's Avatar
both turbo are great!!! but u deffinetly can get more power out off the 50 trim...
Old Jan 20, 2007 | 09:20 PM
Bdub25's Avatar
50 trim = pump monster.
Old Jan 20, 2007 | 09:24 PM
Bdub25's Avatar
AMS all the way
BoostWhore's Avatar
I love my 50 trim, its a turbotrix kit. IT made some damn good power on pump but i finally decided to add meth and it was def worth it
Old Jan 20, 2007 | 09:29 PM
midwestmonster's Avatar
I have AMS' 50 trim kit and love it. You can see my numbers in my signiture. This was done with a clutch on the way out in 95 degree weather humid as hell out. I do have their intake manifold too. That is the only mod I have that most people don't. Otherwise, it's got HKS 272s, AMS fmic, ic piping, tbe, etc. It was tuned on a utec if that makes a difference. I love the kit. My motor is stock as well. I think my numbers speak for themselves. Car was tuned at AMS by Martin.
Old Jan 21, 2007 | 06:27 AM
David Buschur's Avatar
We are waiting on turbine housings to be machined for our BB 50 trim kits. It looks like our other cast manifold turbo kits. They will be $2995 like our other kits. I am going to work on making the kit fit with the stock engine fan and using a 38 mm gate when we finally get the turbine housings. If I can do this I should be able to drop the pricing down to $2795.
Old Jan 21, 2007 | 08:33 AM
dsm_mikey's Avatar
Dave, it sounds like you are doing your best to make a 50 trim affordable for a lot more evo enthusiasts. Will the 50 trim have an edge over the 20G LT in pump gas power or will it be a close toss up? I think that my delima is in line with many others on this board. We are looking for a turbo that will give a good upgrade over the stock evo 9 turbo at pump gas boost levels (22-24 psi if this is possible) with all of the bolt ons you recommend (Walbro 255, Injectors, Intercooler, Intake, Tune, Exhaust, etc.)
I may consider alcohol or meth down the line, but I do not want to depend on it to give any appreciable gains for the turbo I decide to go with.
Also...any feedback on cams for the EVO 9?
Best,
-MIKE
Old Jan 21, 2007 | 10:52 AM
EDL's Avatar
EDL
+1
Old Jan 21, 2007 | 12:02 PM
ray3328's Avatar
$2795 for a BB 50 trim would be a great deal.
Old Jan 21, 2007 | 03:01 PM
daisaw1219's Avatar
i thought i saw a post that davidbuschur made that the 50trim would be under 2k for the kit
