oem intake tube/Airbox/MAF is $HIT
Old Apr 23, 2007 | 05:08 PM
  #46
UCB's Avatar
UCB
Originally Posted by Smogrunner
Bryan,
You may very well be right that aftermarket boxes choke power at higher rpms. If you look at the dyno I posted, the pull with no filter DID make more whp over 6500rpms with a peak gain over around 7whp at 7500rpms. Also, I'll post up the same graph again, but this time with the air/fuel graph expanded to more clearly show differences. My guess is that we are both right: there ARE gains (you) but they aren't dramatic enough to justify the removal of the box (me).
You may not have seen any large differences due to your power levels being lower. If you aren't maxing it out such that it becomes a restriction, switching to a better flowing unit may not be as beneficial
Old Apr 23, 2007 | 06:14 PM
  #47
AfireINSIDE's Avatar
I have been wondering this myself, I am getting rid of my ATP gt3076 kit for a green here this summer, my tuner Tym Switzer wants to use a stock box and a drop in filter. He says he runs a stock box on his car and loves it. I am going to bring in part of my setup and do a back to back stock vs my custom K and N style intake. Might be awhile though...... I just dont know what to belive!!!!!
Old Apr 23, 2007 | 10:30 PM
  #48
RazorLab's Avatar
Originally Posted by Ted B
FWIW, you may want to re-read that entire discussion, and consider the data and the 'devil in the details' along with it.
I would love to know the 'devil in the details' as I was there, changed the filters, and did the tunes on that car.
Old Apr 23, 2007 | 10:40 PM
  #49
Erik@MIL.SPEC's Avatar
Maybe you can ask Tym about when they pulled the stock box off the White Rabbit back in the day of its early hype and it put down over 400whp. It seemed to be a restriction then
Old Apr 24, 2007 | 05:48 AM
  #50
Ted B's Avatar
I was referring to the MAF readings in particular.
Old Apr 24, 2007 | 11:15 AM
  #51
nj1266's Avatar
No need to get angry with us, we're just illustrating the potential effect of variables that you didn't consider that affect the outcome of such tests. And yes, 10 days and 10 degrees difference (according to the weather records for Hayward, CA) do create issues of variability.
No one is questioning that a good intake isn't potentially worth something. What needs to be done when testing different air intake assemblies has been discussed ad nauseum, and it's a bit tedious if quality, reliable data is going to be generated. We didn't make it that way, we're just illustrating what and why for the benefit of those who may be misled into believing that bolting on an aftermarket intake is going to net them 25whp.
That is when dyno correction factors come in handy. If you correct both of Bryan's runs to STD, then the weather variables become constants and you will have a very good idea about the gains from the open element filter over the stock box.
Old Apr 24, 2007 | 12:13 PM
  #52
Ted B's Avatar
It would be great if it worked so neatly. There wouldn't be any point in making back-to-back comparisons if it did.
But it doesn't, or at least not in my experience.
Old Apr 24, 2007 | 12:17 PM
  #53
Well, maybe when I get all my parts together, I can swap out the stock box for the ARC intake I am going to put on.
Old Apr 29, 2007 | 10:16 PM
  #54
JohnBradley's Avatar
Originally Posted by vwjeff
I dont understand UICP's like that , those alone would perform worse than the stock pipe
It replaces the exact layout of the stock UICP but doesnt have the flex sections that will balloon when boosting. I am confused by your comment, perhaps you could enlighten us?
Bryan check PM's.
Old May 4, 2007 | 06:33 PM
  #55
JDMevoBOOST's Avatar
he's talking about it necking down to a smaller diameter
Old May 4, 2007 | 06:46 PM
  #56
Well since he must have one he knows it necks down? Its actually larger than stock and there are no "neck down". The weld that is visible is where it gets bigger.
MITVRX
Jul 26, 2017 09:18 PM
evo_soul
Lancer Engine Tech
20
Dec 15, 2009 02:01 PM
kraig
Lancer Engine Management / Tuning Forums
11
Apr 22, 2009 04:14 PM
dubbleugly01
Oct 5, 2006 09:32 PM
