I Just Blew My Motor!
Old Jan 30, 2007 | 08:44 AM
  #106
superscout03's Avatar
Originally Posted by MSTR MR9
All i can say is that I am in awe of what happened. Supposibly last night after the tow truck came and picked up the car and were on the way to their lot, the car caught on fire and burned. I have no clue how this happened.
"Thats my story and im stickin to it"
Old Jan 30, 2007 | 08:46 AM
  #107
High_PSI's Avatar
Originally Posted by Evo4u2envY
Are you kidding me? How much "knock" where you experiencing that was KILLING your car up top, and what is the crazy AFR you claim mark left you at to be lean? Curious...because, there could be other reasons why the car is dead up top...how about the whole boost thing?...where the stock turbo will never hold the boost it spikes to on PEAK torque....how about a bad tank of gas that could cause the car to switch ignition maps upstairs?...boost leak? Creep? Maybe the boost is spiking higher due weather change? OR better yet, what are you revving the car to? There is no powerband after 7k on a BPU evo 9..the car falls on its face after 7k, but im sure you knew that...and im POSITIVE your miracle tune didn't really do much, if anything at all... but if your claiming 5mph from your tune, rather then Marks, im game...tune my car for me...i want 128mph on pump!
First of all your not POSITIVE of anything, it wasn't even my NEW Evo IX so your wrong right off the bat, calm down please....It was an Evo VIII Btw. On the Dyno it was fine and my A/F's at WOT were between 11.5-11.8 which ran great on the Dyno Jet. As soon as I hit the street the car would start off fast then bog down like crazy up top. I was only trapping at 106-107MPH with cams and ful boltons so I knew something was up. How bad a tank of gas??? are you kidding? And it wasn't a "Miracle" tune. I simply added fuel....easy. This isn't rocket science.
This was on my older Evo, quit making excuses, the car was tuned LEAN, I fixed it by adding fuel, it picked up MPH and topend. It's a testamnet to the OEM Knock sensor pulling timing to save my motor. I had it pulling nicely to 7500BTW....
Old Jan 30, 2007 | 09:42 AM
  #108
cfdfireman1's Avatar
If the car had 3” of water in it I doubt that the tow truck driver put it out himself. Get in touch with the local Fire Dept and get a copy of the report that was filled out, its public information and they will be more than happy to give you a copy. The whole fire story sounds suspect to me and the report will have information as to location of fire, cause and origin.
Old Jan 30, 2007 | 09:52 AM
  #109
Silver06evo9mr's Avatar
i need those pics i cant wait, this thread became crack for me
Old Jan 31, 2007 | 02:17 PM
  #110
MSTR MR9's Avatar
Sorry about the pics, they will be up soon. I dont know why anyone wants to see them but, they will be up tonight, just never got a chance.
Old Jan 31, 2007 | 03:19 PM
  #111
JoizeeX's Avatar
honestly, dont even worry about pics, that's the last thing on your mind. i can't stand how some ppl are obssessed with seeing destruction...get a life! this person is hurting right now and has serious problems to solve, stop bugging him about pics! jesus tapdancing christ... and stop calling BS or "something fishy" on him, just because of lack of pics, don't you ppl have nothing better to do?
this **** just pisses me off, because any time there's a crash or whatever, ppl jump on it like flies on **** and yell "OMFG let's see PiX0rZZ!!11oneomg!!"
Old Jan 31, 2007 | 04:03 PM
  #112
JayZeus's Avatar
Do you need a hug?
Old Jan 31, 2007 | 07:09 PM
  #113
Evo4u2envY's Avatar
Originally Posted by mad_VIII
Spend a little time in the ecuflash area of this site and it should answer most of your questions.
Simple fact is, if the ecu detects what it thinks is knock it will pull timing, 1 degree per 3 knock counts, this WILL kill the power if the knock count is high enough.
Not taking sides on the tune argument, just pointing out that if for any reason, the car was knocking on the street and not on the dyno, the power will be way off from what it dynoed at.
and BTW the ecu does not switch maps due to bad gas, it interpolates between the two sets based on the knock sum over time and uses a time decay to move back to the high octane maps as knock subsides.
-I'd love to spend time in the ecuflash forums; however, i'm too busy on the dyno actually tuning ecuflash rather then reading about it.
-Yes, i understand if the ecu picks up a high count of knock it will kill the power...that would be the computer pulling timing and adding fuel....switching through primary and secondary maps.
-Go to the gas station, put regular gas in your car, and do a couple pulls down the highway and get back to me on whether or not the computer pulls timing if its on a bad tank of gas. I garuntee you, the ecu pulls timing.
Scrolling through the ecuflash forum and picking up a few quick fun facts isn't impressive. I'm not trying to argue either, but it seems to me that your just getting your information from the internet rather then actually having experience with ecuflash.
Old Jan 31, 2007 | 07:18 PM
  #114
7m6m4's Avatar
Wow very sorry to hear that.
Old Jan 31, 2007 | 07:37 PM
  #115
TurbotrixRacing's Avatar
I looked at the log the OWNER of the car sent me... At 2200 rpm.. there was a 3 count of knock .. at 3500 at peak boost / torque.. there was a 1 count .. by 3800 there was 0 all the way to redline. Listening to some a moron in the parking lot telling your friend his car was going to blow up .. so he can try and make me look bad is just bad business practice. He can play all the games he wants.. i really dont give a sh$t. I have plenty of tunes / logs from the super tuner that gave you the great advice.
And just because you read something on a forum does not mean its true.
Hope this helps...
Mark
Turbotrix
Old Jan 31, 2007 | 07:38 PM
  #116
ray3328's Avatar
sucks about the car... good luck with everything
Old Jan 31, 2007 | 09:24 PM
  #117
Mad_SB's Avatar
I don't need to buy sh!ty gas to know how the ecu reacts to bad gas or lean conditions, I had a bad stock injector many months ago and got to experience the fun first hand.
I jumpped in cause it seemed to me you were saying there is no way the car was loosing power up top due to a lean tune.
And no, I'm not just getting my info from the internet. I have plenty of experience with ecuflash on my car and a number of others that i have tuned on the dyno. I would dare to say that i have more experience with ecuflash than a lot of folks that get paid to tune for a living.
Old Jan 31, 2007 | 10:55 PM
  #118
reeferman's Avatar
Ahh, What the hell. Sorry to hear about your car man. Post some pics after you settle with insurance, also would be nice to find out what really happened to your motor but for now...
Old Feb 1, 2007 | 02:31 AM
  #119
QuickSilver2's Avatar
Originally Posted by Greg K
do not get me wrong, I'm just looking at the situation logically to make a suggestion: You had a relatively lightly modded car, with relatively low miles, given these characteristics, you managed to, destroy (1) transmission, destroy (1) clutch, and have the motor fail (presumibly a ventilated block). I'm not accusing you of breaking the motor yet. It seems to me that you have (3) options on how to proceed:
(1) reconsider the style of driving you plan on doing and ensure you have the budget to support that plan.
(2) buy a new evo and change the way you drive (use it as a street car rather than something you beat the hell out of and throw a ton of mods on)
(3) buy something else.
It seems that maybe perharps (am I ambiguos enough) that OP should be looking at domestic V8 monsters, i.e. Magnum, GTO, etc
I've always felt rally cars are not totally about humongous power but about knife edge dancing (aka handling), etc
Old Feb 1, 2007 | 02:47 AM
  #120
hagala's Avatar
um this is the same guy who did a huge bull **** over in Clubrsx.com forums..
no pics? thread = bull **** and everyone is wasting there time plus me..
this guy ran a huge bull **** over at CRSX about how his EVO went off a cliff or something
anyways have fun guys
damn noobs
