Warning for anyone who cares about their transmission...
Old Jan 31, 2007 | 02:45 AM
  #46
Evo_SpeedKing's Avatar
i use 2 parts BGII and 1 part Neo RHD...shifts like butter!
Old Jan 31, 2007 | 05:35 AM
  #47
Fourdoor's Avatar
Originally Posted by KartaRailed
I was running AmsOil 95w gear oil in my tranny, shifted like butter, and this stuff was so thick, I tried changing it on a cold day, (36 degrees) and I had a hard time getting the oil to go into the transmission. Its quality stuff, and I only used it because the mitsubishi dealers local didnt know what Diaqueen was.
I helped a friend with his 3000GT VR-4 and BG synchroshift on a cold day. I put the fluid on the heat vent in my bathroom for an hour befor he got to the house to avoid the "no pour" problem
Keith
Old Jan 31, 2007 | 06:39 AM
  #48
94AWDcoupe's Avatar
Originally Posted by Cirrusly Evolvd
I have used Royal Purple and I hated it. Even in warm weather it felt like shifting through frozen pudding. Imagine how thick it was in cold temps! I use nothing but Royal Purple in my engine but I'll never use it in my trans again.
I think you may have a clutch issue. I have used just about every fluid out. I build trannies locally like TRE and SHEP. I have seen the insides of over 200 trannies. I have broke many gears in my 10 second dsm tranny. I simply love the royal purple. Protects the gears far better than GM synocromesh. And it shifts better as well. The GM sncromesh I found is a poor protector of gears . It also shifts great for a about a month then it goes downhill fast. I have royal purple in all my trannies. Its a gl-5 fluid which is better than any brand gl-4. Gl-5 has an extreme pressure additive in it and is very important to extending the life of your gears. Gl-5 is mandatory in a t-case where hypoid gears are used. Hypoid gears slide over each other rather than roll over each other. The sliding motion is very hard on the gear teeth. The EP additive is designed to deal with this friction of the sliding motion. The EP lubricant is necesarry for the t-case to survive. It extends the life of your tranny as well. The trannies that I use with royal purple seem to shift smoother and smoother the longer its in.
Old Jan 31, 2007 | 07:32 AM
  #49
Ultimate CC's Avatar
Do you have any experience with the redline mt90?
Old Jan 31, 2007 | 08:35 AM
  #50
tkklemann's Avatar
Interesting information on the Royal Purple oils...
Looks like we are 1/1 on good/bad experiences.
I am running Royal Purple in my Tranny, Transfercase and Rear axle now.
I seem to like it so far, and have not noticed any more harsher shifting/gear noise/etc..
I have only had it in the car for approx. 3000 miles now, so I won't know for about another 3-4,000 miles if it has any negative effects. (Just to make sure
my car is OK with the stuff, I am going to drain all and refill in another 3-4K miles)
But, thus far, I like the Royal Purple.
Old Jan 31, 2007 | 08:47 AM
  #51
Smike's Avatar
Just to sum up some of the info, here are some of the links of the fluids we are talking about here--
Redline MT-90:
http://www.redlineoil.com/products_g...7&categoryID=7
Royal Purple Synchromax:
http://www.royalpurple.com/prodsa/scmax.html
Cant find a good BG Syncoshift info page...
Old Jan 31, 2007 | 09:27 AM
  #52
Cirrusly Evolvd's Avatar
No clutch issue, just an issue with the wrong fluid for the car. I used the RP when my clutch was still stock. I had used Redline, BG and OEM before and after the RP and my transmission shifted fine with everything BUT the Royal Purple.
Shepherd and TRE both say to DEFINITELY NOT use any GL-5 oil in the trans. I'm not going to type out the entire reason why they both have told me that and they both gave me enough explanation as to why it's bad for the Evo.
Old Jan 31, 2007 | 09:41 AM
  #53
SPANKED's Avatar
Good info...thanks Dan.
Old Jan 31, 2007 | 09:44 AM
  #54
DaWorstPlaya's Avatar
Shepherd and TRE both say to DEFINITELY NOT use any GL-5 oil in the trans. I'm not going to type out the entire reason why they both have told me that but the both gave me enough explanation as to why it's bad for the Evo.
That is correct! It is not advisable to switch to a different GL rated oil ...
Old Jan 31, 2007 | 09:53 AM
  #55
AutobonEvo's Avatar
IM so confused when i got my tranny rebuild by shep he told me to use syncromesh???
Old Jan 31, 2007 | 10:45 AM
  #56
GL-S is very close to GL-4 from what I gather ...
Old Jan 31, 2007 | 10:51 AM
  #57
modvp's Avatar
I was a little hesitant in buying the BG syncromesh stuff and after reading this, I am happy I was a bit hesitant. I will be purchasing 3 qts of the redline MT90 (GL-4) oil for my Evo.
Old Jan 31, 2007 | 11:55 AM
  #58
Nothing wrong with the BG stuff...like I said before, both shops recommend it.
Old Jan 31, 2007 | 12:30 PM
  #59
AutobonEvo's Avatar
iv heard horror stories with redline, thats why im hestitant to use it. Maybe ill switch over to the BG.
Old Jan 31, 2007 | 12:32 PM
  #60
what did you hear?
