Warning for anyone who cares about their transmission...
Old Feb 20, 2007 | 06:28 PM
  #91
saetern's Avatar
i just switched my tranny fluid out yesterday with RP 75w-90 from OEM, and it doesn't shift as well as it did with the OEM, car has bout 15600 miles on it. Any body know y, is it just cause the fluid is thicker?
Old Feb 20, 2007 | 06:38 PM
  #92
Cirrusly Evolvd's Avatar
Isn't the RP a GL-5 fluid?
Anyways, I had the same problem with RP so I quit using it.
Old Feb 20, 2007 | 07:13 PM
  #93
saetern's Avatar
yea it rated gl-4 and gl-5, people on forum said it was fine. second gear especially its like i gotta force it in. What you use now, i heard that the syncromesh rp is good, cause i got the maxgear one, and shops in alaska don't have redline mt90
Old Feb 20, 2007 | 07:20 PM
  #94
I order my Redline MT-90 from AMS or I buy BG II here locally.
Old Feb 20, 2007 | 08:20 PM
  #95
AfireINSIDE's Avatar
i get mt-90 locally
Old Feb 20, 2007 | 09:03 PM
  #96
Nitrotiger's Avatar
I am going to stay with the oem fluid seems ok to me
Old Feb 20, 2007 | 09:12 PM
  #97
saetern's Avatar
yea i might have to switch back to oem after this, we'll c if i have any metal shavings next tranny oil change
Old Feb 28, 2007 | 10:55 PM
  #98
RUDEBOY77's Avatar
What Order?
I'v been pulled so many directions on this thread! What I've gathered is that there were many different personal experiences with several types of tranny fluid. If there was a ranking system, how would everyone put these products in order?
redline MT-90
PENZOIL SYNCROMESH
BG SYNCROSHIFT
BG SYNCROSHIFT II
ROYAL PURPLE SYNCROMAX
Old Mar 1, 2007 | 03:49 AM
  #99
No on the pennzoil I changed it 2 times in less than 5000 miles due to it breaking down and developing notchyness. And I would prob stay away from BG 1 and go with the 2 if you like BG due to synthetic/non synthetic.
Old Mar 1, 2007 | 06:48 AM
  #100
RUDEBOY77's Avatar
redline MT-90
PENZOIL SYNCROMESH (bad)
BG SYNCROSHIFT
BG SYNCROSHIFT II
What about the rest of the products? Any takers?
Old Mar 1, 2007 | 09:03 AM
  #101
20psiMR's Avatar
DISCLAIMER!:
If you have a 6 speed, pretty much pay NO attention to any part of this thread. It does NOT apply. DO NOT USE MT90 IN THE 6 SPEED TRANSMISSION. PERIOD. This has been discussed ad nauseum in countless 6 speed tranny threads, do a search. Our stock fluid is thinner, and need to use SUPER Diaqueen 75/85 or equivalent. The GM fluid is 75/85, and I havent heard of any issues using that in the 6 speeds. BG2 and the Pennzoil also work, but theres so much hearsay on all 3 of these that its almost best to just use stock. Personally, I had a synchro go at 9k miles running the bone stock fluid, so who knows. (Hadnt changed it yet.)
Also, for all those preaching MT90, and thats what Shep and TRE recommend, your only half right. Its 2 quarts MT90 and 1 quart Heavy Shockproof. They dont recommend just straight MT90. Use OEM fluids (diaqueen) in the TC/Diff.
Old Mar 1, 2007 | 02:33 PM
  #102
Evoryder's Avatar
Originally Posted by 20psiMR
DISCLAIMER!:
on the 2:1 mix
Old Mar 1, 2007 | 03:01 PM
  #103
pog0's Avatar
I am using what RRE recommended. BG II in the transmission, shockproof for transfer case, mt90 in the rear end. Shifts the same as it did before I changed the fluids out.
Old Mar 1, 2007 | 03:23 PM
  #104
rraulston's Avatar
None of the above oils would i use......Super diaqueen in the tranny and Hypoid Diaqueen in the diff and tfc.........Just because the redline is synthetic and ULTRA slippery, its TOO slippery and shifting is a problem. Look, put the mt-90 in your car. Run for 1 month.......then put in super diaqueen....run for 1 month. 5 bucks says you will keep the super diaqueen. Opinions on here are just that.....do this test yourself and answer your own question.......alot of us allready have......RRR
Old Mar 1, 2007 | 03:26 PM
  #105
Evoryder's Avatar
super diaqueen? LINK
$5 is where your confidence level is at with this product?
