Warning for anyone who cares about their transmission...
Old Mar 7, 2007 | 04:09 PM
  #121
Ultimate CC's Avatar
Well I have been driving my evo for some time since the rebuild with the redline mt90 in the tranny and diaqueen in diff and tcase...one the car does not go into gears when super cold, not a problem as i warm my car up before every drive, 2 once its warm you run through the gears once or twice and its butter and i can't say enough about it...
Old Jul 19, 2007 | 02:18 PM
  #122
Smike's Avatar
I have to write up a poor review for BGI. I put in BG at 55k and by 60k it was getting hard (lock out) to get 2nd gear - no change was made to the clutch adjustment.
I happen to be at my dealer at 65k for some sensors and since the lift was open had the trans fluid changed out to the Amsoil Trans fluid I had just gotten in from my shop ((https://www.amsoil.com/storefront/mtg.aspx)).
Once we opened the fill plug - note fill plug. Trans fluid came gushing out. I put in the exact 2.9 qts at 55k. Now 10k later the fluid had broken down or expanded to many times its original volumn. The warm (but not hot) fluid also was about as good as water. Just didnt stick to your fingers like fresh/good fluid should. Luckly the drain plug magnet was clean (no metal at all).
Amsoil when in and all gears shift like butter once again. Been on the Amsoil now for 1500 mi or so. And so far so good. Even when I get the car hot - no shifting issues. Waiting for a track day for a full review on it all.
So in short - BG sucked. I dont recommend that stuff to anyone. Use Amsoil, OE, or Redline.
Old Jul 19, 2007 | 02:22 PM
  #123
AfireINSIDE's Avatar
i just put in the 2qt of redline mt-90, 1qt of redline MTL and is working great for me thus far!
Old Jul 19, 2007 | 08:40 PM
  #124
shuttlegoose's Avatar
yeah so i just read 2 threads and diaqueen seems to be the safest bet, i remember when i had my suby it was all about the redline shockproof, but thats cuz the trannys are made of glass.
Old Jul 25, 2007 | 09:21 PM
  #125
hanahawaiian's Avatar
im going get Super Diaqueen oil in my 5 speed tranny and TC and Rear will be Diaqueen LSD gear oil.... ill stick OEM
Old Sep 18, 2007 | 05:51 PM
  #126
lem's Avatar
lem
redline's powerpack for the evo is to mix 2qt. MTL(70W80 GL4) + 1qt. MT90(75W90 GL4) = 75W85 gear spec.
Old Sep 18, 2007 | 06:06 PM
  #127
lem's Avatar
lem
redline's powerpack for the evo: mix 2qt. MTL(70w80GL4)+1qt. MT90(75w90GL4)=75w85 gear spec for the transmission. 75w90 gear oil for the transfer case and rear diff.
Old Oct 30, 2007 | 04:46 AM
  #128
justchil's Avatar
I wish I would have seen this thread about 2 years ago. I've been using BGII but just ordered some MT90. After changing my trans fluid this past time I saw TONS of shavings... once the fresh BGII is in my car now pops out of gear about 75% of the time in 4th. My trans is on it's way out for sure.. thanks BG! lol
I will give the MT90 a try just to see if the friggin thing will stay in gear. I wanted to get a few 1/4 mile passes in Friday just to see what it will do before I put her down for the winter.
(sorry for the off focus)
BTW: Always used OEM fluids in the tcase/rear diff and with 70k miles miles of abuse they show no problems.
Old Oct 30, 2007 | 07:27 AM
  #129
8thWonder's Avatar
^^^Yikes! I've never seen so many shavings!! The whole plug is covered! I used BGII for 2 changes but switched to Super Diaqueen which improved shifting incredibly! I'm going to continue using Super Diaqueen in the tranny and Diaqueen in the xfer/diff.
Old Oct 30, 2007 | 07:31 AM
  #130
06MRV8Killer's Avatar
OMG thats crazy!
Old Oct 30, 2007 | 07:33 AM
  #131
SPANKED's Avatar
I just did my first tranny fluid change at 16K and went with Super Diagueen...I didn't notice much of a change in shifter feel and it did not remedy my 5th gear grind which just started...sucks...
Old Oct 30, 2007 | 08:31 AM
  #132
MikSchultzy's Avatar
I've started to use MT90. Did it on my first change, and will once I put her back together again.
Old Oct 30, 2007 | 08:34 AM
  #133
Paul Nelson's Avatar
Originally Posted by Ultimate CC
yea but you were trapping only 109 which isn't a ton of power...you first bunch of passes were in the 13s as were mine were all 12.00s and the last month was low to mid 11s (not posted for a reason )...
Man i just don't understand why i see metal shavings in my tranny only after 10 passes???
Old Oct 30, 2007 | 08:41 AM
  #134
deadbeatrec's Avatar
so basicly use the following....
Redline MT-90 for the 5 speed evo trans (NOT THE 6 SPEED)
Diaqueen GL5 for the front and rear diffs.
Old Oct 30, 2007 | 08:48 AM
  #135
8thWonder's Avatar
Not good. But since you went from the stock fluid to the Super, there may not be much of a difference. It was a night and day difference switching from BGII to Super Diaqueen.
