Need Help!!! Emergency!!
Old Jan 30, 2007 | 09:25 PM
Evoryder's Avatar
Ohnos, emergency!!!1 It amazes me how people have a car like the Evo yet don't even know the symptoms of a slipping clutch.
...i'm sure you were born with a wrench and automotive manual , just a little ridiculous sometimes...get over yourself.
*Back on topic*
Good luck with purchasing a new clutch, I love my exedy twin...when this goes out...i'm going with another.
silverEVO8's Avatar
Originally Posted by Evo9"Miss Rose"
exedy would be your best bet...but if you like your stock feel and you dont really plan on putting power to the ground then just get a stock one...
Stock clutch is best unless you want to beat the car. I had the Exedy twin plate and it was definitely less streetable. To each is own, but for everyday driving I'd vote stock.
Evo9"Miss Rose"'s Avatar
Originally Posted by dsycks
Anyone else think it could be the clutch?!
As for killing a clutch. You should see what a VW TDI can do to a stock clutch after chip and injectors... Going from 150 to 325lb ft does bad stinky things to a stock POS clutch.
Been there done that with chip and cat-back but on my 1.8T
Old Jan 30, 2007 | 09:26 PM
lightspeed1's Avatar
Well....I will admit..I truly believe that the dumbest question is the one that never gets asked (seriously). FWIW...Evo's are one of the highest rated performance cars out there. HOWEVER, I personally think that the clutch on a VESPA is much stronger than an evo oem clutch. On the other hand....I am proud to have 62.5K miles on my oem...(no drag launches!) :-)
NIevo's Avatar
Sorry but there are alot of times when I have better things to do when Im in a hurry then sift through 5billion pages of alot of useless crap to try and find just the answer Im looking for. Alot of us dont mind answering simple questions to help someone out because sometime in the future we might need help in return.
Unless of course its one of the "How Can I Make the PFFFT Blow-Off Valve Noise" questions. Then there should be a lynching!
Old Jan 30, 2007 | 09:27 PM
Sorry i should of said Exedy would be your best bet if you plan on putting mad HP in the EVO..
Old Jan 30, 2007 | 09:30 PM
blackbichGSX's Avatar
Mine had the same problem! After the Exedy Twin the problem went away. Now I am
Old Jan 30, 2007 | 09:31 PM
dsycks's Avatar
Wait... you mean there is an easy and BETTER way to make that noise and I didn't know about it?! Swoon!!!
Actually I don't want to hang anyone for asking a question that many of us would find simplistic but this one was sorta a tee shot.
Funny you should say that NIevo I just discovered that "PFFT" sound.....(damn Taco Bell!!)
NIevo's Avatar
I have the Cusco Twin Disc which is the same as the Exedy and it is very streetable. Since you are doing the clutch anyways you might as well upgrade.
Old Jan 30, 2007 | 09:33 PM
heavens turbo's Avatar
lolololololo, of course a police officer with an evo will have good mileage on his clutch..... it would be wrong to speed! by the way, if you're a real cop, have you chased anyone down in the 'vo? lollololo, that would rule! oh, and i vote "clutch".
Old Jan 30, 2007 | 09:34 PM
NIevo's Avatar
So are you VTA or Recirculating?
Old Jan 30, 2007 | 09:37 PM
Funny you should say that! About 2 weeks ago I chased a DUI (lexus SC300)down the grapevine till the CHP showed up....when you tell dispatch your an off duty cop... they tell ya "have at it!" I wouldn't have done it though if it wasn't 3:30 AM (NO traffic)
Old Jan 30, 2007 | 09:38 PM
dsycks's Avatar
I'm a VTA guy but my wife wants to find a way to make me recirculate.
It depends on the psi! Some times I compressor surge!!
