do you guys have the same problem
Old May 28, 2003 | 07:52 AM
evoinit's Avatar
ok in the evo when you are goin around a turn..
not at a fast speed do you feel something like rub a little bit
or is it just the factory camber settings...
Old May 28, 2003 | 09:24 AM
mayhem's Avatar
i've never felt a rub.
Old May 28, 2003 | 12:52 PM
1QWKEVO's Avatar
Make sure your EVO's shipping blocks are not still installed in the front struts my (censored) dealship never removed mine when they supposidly did their initial inspection on the car.
Actually I itnhk what you are hearing is the loud stock tires, they have a lot of road noise, i've noticed mine hum around turns when i don't use the brakes and when i'm breaking at slow speeds to a stop i've heard the same noise.
Old May 28, 2003 | 12:59 PM
mayhem's Avatar
after i first posted i went for a ride. i paid special attention to turn in noises. i did hear the rubbing sounds as described. as !QWKEVO thought i think as well. it sounds similar to the loud brake noise but is most likely loud road noise from the tires gripping.
Old May 28, 2003 | 04:13 PM
evoinit's Avatar
good **** guys thanks alot you made me feel alto better
Old May 28, 2003 | 04:21 PM
cky3396's Avatar
what are shipping blocks, how do you remove them?
sorry for being a noob
Old May 28, 2003 | 04:38 PM
evoinit's Avatar
yeah i would like to nkow about the shipping blocks also
Old May 28, 2003 | 04:54 PM
zx6r's Avatar
Someone posted a pic of them a few days/weeks back ? I tried a quick search but couldn't find it again. As they say a picture speaks a thousand words.
Old May 28, 2003 | 05:24 PM
1QWKEVO's Avatar
Mine are out in the garbage but I can go get them and post later.
They are 6 inch pieces or solid rubber that are located on the inner side of each front strut assy. The middle of the black wraps around one coil and the block extends to the next upper and lower coil. They are suppose to be removed durring the initial inspection when your car comes off of the truck to the dealership. I ran 2100 miles on my car before noticing them still in there, i'm really mad... I should keep them and lower my car and when I do end up breaking something take the car back in with shipping blacks and tell them those where in there since i bought the car, how else would I get ahold of something like that.
I'll post a piture tonight if I still ahve the blocks
Old May 28, 2003 | 06:47 PM
jfh's Avatar
jfh
check out this thread for shipping block pic and additional FAQs you might find informative:
https://www.evolutionm.net/features/...vo&id=14&s=#51
Old May 28, 2003 | 06:51 PM
jfh's Avatar
jfh
Re: do you guys have the same problem
No rubing sounds, as in something rubbing against the car, but sometimes there is a scrubbing sound from the soft tires gripping the road surface. This is common in many cars running extreme performance tires.
Old May 28, 2003 | 09:25 PM
1QWKEVO's Avatar
there you go, those are the SOB's
here forget the link
Old May 29, 2003 | 07:47 PM
svillata's Avatar
have same sound.. I don't "feel" anything, just hear it, yeah, same sound as the brakes, that low rub/grind type noise. At first was concerned. Thought maybe the pads were rubbing when I trurned or something... but could not FEEL anything, and that would probably make a squeel or squeek or something. Actually had that on my porsche where they were adjusted to close or something and would rub on when I turned... but it squeeked also and was louder and you could kinda feel it.
anyway, so i guess its just the tires like everyone says.
Old May 29, 2003 | 11:32 PM
Evo D's Avatar
Got my EVO last Friday, Jeez, no wonder the ride was so bad I feel so stupid, have done *a lot* on cars for years, even put the thing up in the air to check it out, how the hell did I miss THESE???
Hope this isn't too redundant, this image really shows how they look on the car & off. Mine had 2 on the driver's side, only 1 on the passenger's.
Seems like an epidemic!
Dan
Old May 29, 2003 | 11:47 PM
1QWKEVO's Avatar
Great post, looks like mitsu isn't doing their job. Mine hade one on each spring. Rides like a new car huh...wait a min it's suppose to be a new car.
