act hdss or xtss for 500whp
Old Feb 4, 2007 | 06:53 PM
riceball777's Avatar
most ppl here have the act hdss. i was wondering if the xtream pressure plate was a better choice. i'm thinking about geting a gt3076r soon. so which clutch is better for about 500whp. the xt pressure plate only cost less tha $100 more.
also how much stiffer is the clutch pedal with the xt pressure plate.
Old Feb 4, 2007 | 06:58 PM
Warrtalon's Avatar
500whp? Neither, but if I had to choose, I'd say the Extreme one, of course. The HDSS is only rated to 497 FLYWHEEL torque, so keep that in mind.
With that much power, you should have nothing less than a twin plate like the Exedy HD...
Old Feb 4, 2007 | 07:29 PM
derangedazn's Avatar
OEM Clutch all the way !!!!!!!!!!!!!!!!!!!!
Warrtalon is correct go Exedy Twin Disk and save yourself some headaches down the road
Old Feb 4, 2007 | 07:39 PM
dafunk630's Avatar
im going with the extreme pressure plate kit
Old Feb 4, 2007 | 10:15 PM
well i will probably run 91 octane 95% of the time so most of the time i will be at or under 400whp. i only want to run c16 through it once and a while. i also really dont want to spend $1500 for a twin disk.
i just want some feeback from some ppl that have the xtss because almost everyone here with an act clutch has the hdss and not the xtss
Old Feb 4, 2007 | 10:16 PM
evo542's Avatar
check out tilton twin disk (ceramic) it definetly blows away the exedy twin in holding power(750 ft lbs) and much lighter assembly only 19.1 lbs for the whole thing vs like 30lbs stock disk
Old Feb 4, 2007 | 10:19 PM
Blue Evo 8's Avatar
I'm making ~500 AWHP and am using the XTSS w/o any complaints
Old Feb 4, 2007 | 10:22 PM
thats great to hear. how much wheel torque are u making with the 500whp. hows the drivability of the clutch. does it chatter. is the clutch pedal really stiff?
Old Feb 4, 2007 | 11:40 PM
Warrtalon's Avatar
It's a 3100# pressure plate - of course it's stiff. However, that should not be a worry. I don't know why people go for 500whp but then worry about the clutch pedal being stiff, but then again I also can't see how someone would spend that much money on a big turbo upgrade yet not get a proper twin disk. Many things confound me.
Evo542, no, the Tilton Twin does not blow away the Exedy Twin in terms of power holding capacity - what made you say that? Also, did you mean to say cerametallic, or were you really referring to a ceramic clutch?
Old Feb 5, 2007 | 05:54 AM
2StepsAhead's Avatar
Well some people are worried about the recent posts of people burning up exedy twins under normal driving, I myself have no problem spending the extra money on a twin over an act BUT I want to only do this once....I don't want to spend 1400 on a clutch and 400-500 on install and have problems, just like I don't want to spend 600 on an act + the install and have problems.
Old Feb 5, 2007 | 06:03 AM
rraulston's Avatar
i have the xtss and can smoke it like stock if i am not carefull......459/430.....the pedal pressure is stiffer, but after an hour, you dont notice it anymore.....and i had to adjust my pedal to maximum. Go with the Twin........
Old Feb 5, 2007 | 06:15 AM
03silevo's Avatar
twin plate all the way............
Old Feb 5, 2007 | 06:48 AM
deadbeatrec's Avatar
i love my act, and its half the price of the twin with a new lightened flywheel.
Old Apr 2, 2007 | 10:45 AM
High_PSI's Avatar
What is the torque rating of the twin?
Old Apr 2, 2007 | 11:06 AM
Sap12687's Avatar
I have had experience with both the ACT Heavy Duty and Xtreme Pressure plates. I just recently switched out the Heavy Duty for the Xtreme and the difference in pedal feel is negligible. I for one don't mind a stiff pedal so it wasn't a deciding factory in my purchase.
I went with ACT because of the great track record and amazing customer service. I also hear a lot of positive things about the Exedy but i didn't feel it was necessary to spend more than a grand when i don't plan on making more power than the ACT can handle.
