Any risks if boosting up to 25 psi
Old Mar 26, 2011 | 06:56 PM
ihockey1's Avatar
Im pushing 27 lbs on an aggressive ttp tune and I still haven't nuked my motor (knock on wood) and im still have stock injectors w a walbro on 93
Old Mar 27, 2011 | 05:48 AM
RyuEvoIX's Avatar
Volcano, you honestly expect an answer out of a 4yr old thread from a guy that doesn't even frequent the forums anymore?
Warrtalon
Offline
Last Activity: Dec 17, 2010 11:51 PM
Congrats guys, you've successfully raised the dead.
Old Mar 27, 2011 | 07:10 AM
920rs's Avatar
^^^^dude, really .....a post from Feb 2007? Tuning has changed so much from then. Check out the dyno sectionor something for more updated info. Ha
Old Mar 27, 2011 | 07:20 AM
wizzo 8's Avatar
I was running 30psi on my stock turbo with 93 and meth.
Old Mar 27, 2011 | 08:07 AM
jackbenimbo's Avatar
e85 running on 26lbs no issues stock turbo/internals
Old Mar 27, 2011 | 05:19 PM
RyuEvoIX's Avatar
33-34psi with 93 and methanol as well.
Old May 9, 2013 | 08:29 PM
Sonicbl's Avatar
I recently downloaded the Cobb AP Stage 1 ACN91 V400 which peaks at 26psi. What do you guys think about that 0_o
Old May 9, 2013 | 08:40 PM
hiboost2.0's Avatar
Holy thread revival. 26psi on the stock turbo isn't too much, as long as the tune going along with it suits it's needs.
Old May 11, 2013 | 07:36 PM
davidhuunguyen's Avatar
26 lbs no prob
Old May 13, 2013 | 07:51 AM
blackenedwings's Avatar
Old Nov 21, 2020 | 10:14 AM
thatredevoXIII's Avatar
Originally Posted by Tribal
the safest you can go on a stock turbo is 23 psi but make sure you have a fuel pump just to be even safer.
Just bumping this post from the dead, but I ran a 22.9 PSI on stock 8 turbo. Mods are 3" downpipe with o2 dump to the ground, ETS 2.5 Lower IC pipe, AMS 3.5" FMIC, stock MAF, stock upper IC. Did I overboost or am I good? It was about 55 degrees out that night.
Old Nov 21, 2020 | 12:03 PM
kaj's Avatar
kaj
Your mods are overkill for the stock turbo, so no worries there. The FMIC may be slowing the turbos response, but that won't hurt anything.
I ran a hell of a lot more than 23psi while on e85. As long as you aren't seeing knock or lean AFRs, you are fine, assuming you are tuned for everything.
LSs1Power
Apr 29, 2017 01:08 AM
scott08X
Sep 20, 2016 04:51 PM
Silver-IXse
May 16, 2013 08:40 AM
honda-guy
136
Feb 13, 2013 09:59 AM
hempele28
18
Aug 10, 2008 09:23 AM
