spring height
Old Feb 6, 2007 | 12:32 PM
dean evo9's Avatar
spring height
i am upgrating to cosworth cams for my 9 ,supertech valve springs and retainers, also getting a triple vale job done and light porting ,ie blend bowl into seat area ect ,my head man asked what the spring height should be ? as he can shim them and make them all the same , i checked around and cant find a answer, can anybody help , thanks
Old Feb 7, 2007 | 01:07 PM
DanInPA's Avatar
http://www.junauto.co.jp/products/cy...lve-spring/?en
I would think that supertech should have an answer for you. After that I would check with cosworth to see if the tolerance from supertech is adequate for cosworth cam.... Above link was for your reference so that you can get those info from manufacturer of your parts.....
Old Feb 8, 2007 | 12:52 PM
dean evo9's Avatar
answer to my question
well after a lot of research i got a hold of a surertech engineer , supertech products are made in argintina, but i talked to a us rep, spring height for a evo9 is 39.6 mm thats with the valve closed ,Supertech offers 3 spring rates for a evo , first, part #m10007s , 78 lbs at 39.6 mm valve closed ,200lbs @ ,11.5 mm, max lift 15.5 mm, #2 part # m10007d 96lbs@ 39.6. 246lbs@11.5 lift , max lift 15.5mm #3the tech said these springs are for drag , short endurance moters as they would actually slow your moter down ,fighting spring tension, part#m10009d 120lbs@39.6mm, max lift not spec ,but the tech said, lift is less than 15.5mm as the inner spring would cause coil bind ,this is all part of blueprinting a moter if your moter builder dosent ask these question about spring height , i wouldnt use them ,as this measurment is part of a pro blueprinted engine build, thanks daninPA as you got me on the right track ,i knew there was a answer to my question thanks all
BR350VIII004
Apr 21, 2016 08:43 AM
TxFAkuma
Jun 13, 2015 12:53 PM
vortico
10
Oct 11, 2012 07:59 AM
whitenblue65
14
May 2, 2007 08:53 AM
dan00780
14
Dec 6, 2005 08:33 AM
