Finally, wicked affordable camshafts....
david, should i hold out for ix cams from you? happening in the next 6 months?
im ready to buy a set of cams, but i trust your parts over others when it comes to serious work. turbo, motor, tuning.. etc...
thanks!
thanks!
with the Cosworth cams. What type of gains can i see i have your stage 1-4 in my 9 right now
Yes, you can use aftermarket gears with these cams. You can set them at 0 or you can rent a dyno and play with them and see if your combination gains in the areas you want the gains.
Actually, having a cam ground for the smaller turbo is an excellent idea and I'm not too sure why I didn't think of doing that. Too many other things on my mind maybe.
hey dave. make us some good cams for your 20g. you said stick with revolvers if you have a small turbo but you made these cams because of the lack of availability of revolvers.
if that made no sense, then let me rephrase.
"hey i can't find ham on the market anymore for my big sandwiches but for those of you who only like little sandwiches, you should just buy ham, im going to be using spam from now on."
I guess us stockish turbo folk will just have to use bologna on our small sandwiches then...
some questions are just unreal
