Finally, wicked affordable camshafts....
I don't know if those will work, I have not tested them and we don't sell them. I'd need to know the installed seat pressure and the pressure at say .460 lift. Then I could guess.
Actually he did. If you are only running 12.2@113, you do not have a big enough turbo to take advantage of these cams.
Hey David just had a general question,
I put HKS 264/272 cams when I was running a stock turbo setup, but now that i'm running a 3076 I was wondering what kind of gains are there on the table if I were to upgrade to the JUNs, Tomei, or even this new cam. Just trying to see if an upgrade was worthwhile, Thanks!
Originally Posted by EVO8_PR
How would the idle be with these cams.
The idle quality is actually better than the Revolvers. These cams absolutely need the best spring and retainer kit available. There are two sets that will work, we carry them both. I do not recommend running them with a reflashed ECU, I don't think they will idle very good.
Hi Dave I have a set of Revolvers on my car as you can see I do have a ported head 1mm the whole nine with supertec dual spring's will theses cam's work with my setup.
I dont like to ask ?'s but i just need to know if they will work with my spring's if so ill be placeing a call very soon to pick up a set.
OK, since you seem to be soooooo smart, how bad is the idle on the revolvers. I't would be of great help if a vid or sound pic could be linked here for us who don't know how to read! Unfortunately my eyes can't hear the idle lope these cams could or would produce.
