Finally, wicked affordable camshafts....
240Z, you can't read can you. We have been running these cams for about 6 months. I have them in a BUNCH of different cars. If you took the time to READ what I spent my time typing you'd see I gave quite a few examples. IN the LAST paragraph I wasted my time trying to explain something to YOU in I said JARROD (who is NOT my brother) with a STOCK head gained 40+ whp and TQ.
Please get off your lazy *** and build an EVO faster than mine so I will finally STFU. It would save me a lot of time, then I could just defer all the stupid comments and questions to you as at that point you would have proven just what it is that you know.
Another 5 minutes of my life completely wasted.........................
These cams will not make as much power as the smaller cams do on the smaller turbos. I never suggest buying a part twice.
I have still never ran a 50 trim, never dyno'd one, never even scene one. We are still waiting on our housings. I have no idea if they'd work out good with a 50 trim. A 50 trim is about the size of the green so I am going to guess no, they will not work well. It is a guess.
If you didn't think I could read then you would know not to ask the question. I said that I apologize and you are clearly smarter than everyone else on this forum and have the fastest car. I even quoted you in my signature just to remind myself of that fact. I should never have questioned your setting the cam timing to zero as you are right by default. Why even bother trying to beat you, it isn't possible. Your technical abilities and solid approach to application develop is mind blowing. Again, keep up the good work and mark me down for a set when you develop them for the IX.
If you didn't think I could read then you would know not to ask the question. I said that I apologize and you are clearly smarter than everyone else on this forum and have the fastest car. I should never have questioned your setting the cam timing to zero as you are right by default. Why even bother trying to beat you, it isn't possible. Your technical abilities and solid approach to application develop is mind blowing. Again, keep up the good work and mark me down for a set when you develop them for the IX.
Just FYI
Quote:
Originally Posted by EVO8_PR
David, for those of us who have upgraded springs and retainers already such as crower, or any other single spring/ retainer design, what problems could we confront with your cams?
Ted B:
One problem you will have is not enough turbo for these cams
FYI
so here I go again...
If I was going to build a set of cams that were designed to run straight up "0" regardless of whether it was a 2.3 liter, or 2.0 liter, or a drag queen or road king..... here's what I'd use
272 deg
235 deg @ 1mm
Lift - 10.8mm
Centerlines - 110 deg Int / 115 deg Exh
LSA - 112.5 deg
But since I'm just an internet bench racer, Dave you're still the baddest and fastest **** on this forum!
272 deg
235 deg @ 1mm
Lift - 10.8mm
LSA - 112.5 deg
lol
Keep up the good work.
https://www.evolutionm.net/forums/sh...d.php?t=245815
https://www.evolutionm.net/forums/sh...d.php?t=248346
definitely will open up the top end.
