New Rear?
Old Feb 9, 2007 | 07:55 PM
tseitz123's Avatar
New Rear?
Apparently I need a new rear end on my 05 EVO VIII. Just what exactly does this mean? I am told that the axles and driveshaft are fine, but that the spider gears, pinion gear, diff, etc. are toast. What do I need here and where can i get a used one?
Old Feb 9, 2007 | 08:26 PM
sparky's Avatar
You need a new rear differential. I know that for the best rebuilt trannies and transfer cases people on this forum use either Shep's or TRE. I guess that both would be a safe bet for the rear differential as well.
Old Feb 10, 2007 | 04:59 AM
joeMama's Avatar
I am in the same boat myself, Unfortunatly shep does not do a rebuild for the rear.
Old Feb 10, 2007 | 06:45 AM
Evo_7's Avatar
i think that you can get the rear diff from Cusco or Ralliart.
Old Feb 10, 2007 | 07:31 AM
tseitz123's Avatar
I'm being told that the rear t-case for the 05 Evo 8 from Mitsu is like $3300. WTF?!!! Where can I get one used? I'm about to pay someone to steal an EVO off a lot and bring it to a lift. I'll just yank what I need off of it. hahaha. Seriously tho, what is involved in the "rear"?
Old Feb 10, 2007 | 07:34 AM
joeMama's Avatar
Im rebuilding my rear with new guts, it smuch cheaper then replacing the whole housing and everyting
Old Feb 10, 2007 | 07:36 AM
tseitz123's Avatar
Where are you getting the parts for a rebuild?
Old Apr 14, 2007 | 12:40 PM
TxEvo8's Avatar
How'd the rebuild go? I'm about to break into mine. Any specs and specifics would be appreciated...
Old Apr 17, 2007 | 10:21 AM
ace75's Avatar
no warranty on this? Ive got an 05 too, and the rear diff was soaked with gear oil. Anyone elsewith this problem? Thanks.
Old Apr 17, 2007 | 11:03 AM
sonicnofadz's Avatar
Don't sweat it! Just take out your OEM rear differential and swap in the ralliart, cusco, kaaz, or quaife. Should be about $1000 or under for just the differential, not hard to do at all.
