rough idle?
Old Feb 11, 2007 | 06:49 PM
chaz517's Avatar
rough idle?
Has anyone experieced rough idle at all when puttin in a tbe without getting a tune? Its not all times but every once in awhile it'll jump up 500 rpms, will a tune even that out? Thanks in advance
Old Feb 12, 2007 | 07:54 AM
chaz517's Avatar
Damn I'm the only one with rough idle huh?
Old Feb 12, 2007 | 08:27 AM
EVO8emUp's Avatar
The only time my car idles rough is when pumping gas into an almost empty tank while the car is running.
Old Feb 12, 2007 | 01:59 PM
steinvb12's Avatar
Most tunes don't even touch the idle, unless you have monster cams and have an aftermarket ecu.
Old Feb 12, 2007 | 03:41 PM
Lamdaprobe's Avatar
From: in a plastic coffin off of Route 1 Bridgeport
you might want to check for un-metered air leaks and it's poss.that the tbe is not causing your concern.maybe an exhaust leak throwing off the pre cat o2,but i doubt it
Old Feb 12, 2007 | 03:53 PM
Silk's Avatar
Im pretty sure every cams except for maybe 264's need at least a little tweak to the idle.
Great information
Old Feb 16, 2007 | 06:48 PM
chaz517's Avatar
it has also been really cold here lately at, especially at night, its beneg etting down to single digits, maybe that?
Old Feb 16, 2007 | 06:50 PM
str8kor's Avatar
i've never experienced that on my evo, even in cold weather, it's been pretty stable, if you get a good reflash it may solve it
Old Feb 17, 2007 | 07:54 AM
chaz517's Avatar
really? damn i read somewhere on here someone else said their evo went up 400 500 rpms at times in the real cold i hope thats it
Old Feb 17, 2007 | 08:24 AM
ries's Avatar
if your car is cold when you start it, it will idle at around 1500rpms til it starts to warm up. Then the rpms will slowly drop until it gets to operating temp...I believe mitsu recommends letting the vehicle warm up and to not start driving until the water temp needle starts to move. I always wait until the needle is past the lowest markjust to be safe.
Old Feb 17, 2007 | 08:26 AM
ries's Avatar
Your rpms shouldnt be jumping around though...If the rpms arent steadily going down during warm up or are jumping around at operating temp I would take it to the dealer and have them check it out...especially since its a brand new car
Old Feb 17, 2007 | 09:17 AM
fastevo03's Avatar
I have rough idle even when the car is stock, changed the spark plug and it was much better.
SpeedI2acerX
27
Mar 14, 2019 06:57 PM
Domengg Domino
Dec 1, 2016 12:07 PM
05EV08
May 20, 2016 10:30 PM
Siluck2
11
Apr 11, 2016 06:06 PM
deegaw11
11
Jul 1, 2007 04:46 AM
