650WHP on E85 and Meth!!! at 36lbs of Boost
Old Feb 15, 2007 | 08:05 PM
  #46
Ted B's Avatar
Originally Posted by mike 99gsx
For example, to my knowledge there is no way to compare durations of cam A measured at .050 vs cam B at 1mm. So you can't guess that a Jun 272 that has an effective duration of 235* at 1mm likely has more RPM potential than a BC 280 which 218* at .050"
Well, you have a point there, and I was going off of some data I had in my head somewhere, but cannot seem to put my finger on it now. You may be correct about the duration, but the 106 deg LC (?) isn't doing anything for high rpm power - and hence my point about cam gears being useful. Or, one could just forego the cam gears like I also indicated, and opt for a cam ground to a more appropriate LC.
If anyone has a cam card for the BC 280s, please speak up and post the particulars.
Better cam timing + ported head = substantial power increase in this case.
Old Feb 15, 2007 | 08:13 PM
  #47
whitey4d's Avatar
Dave has stated the new cams were called BF272s.
Old Feb 15, 2007 | 08:16 PM
  #48
EVOlution561's Avatar
Nice numbers on that setup. That E85 just amazes me.
Old Feb 15, 2007 | 09:56 PM
  #49
superduperhoots's Avatar
Wow I bet the acceleration is no joke. I think I'd **** bricks.
...hmm maybe I could make a house or somethin'.
-Hoots
Old Feb 16, 2007 | 08:36 AM
  #50
dafunk630's Avatar
i wish i can get e85 in CT
Old Feb 16, 2007 | 09:55 AM
  #51
Paul Nelson's Avatar
Ted were going to try the cam gears and boost leak check first. If we don't see much of a improvement then we will switch the cams and than as a last resort port the rest of the head
Also were going to play with c-16 vs E85 and see what the difference between the two we get
Old Feb 16, 2007 | 11:59 AM
  #52
Spooldyou's Avatar
the only location that is even remotely close to us is in Chelsea MA, that i know of. Already did a search for that!!
Old Feb 18, 2007 | 12:10 PM
  #53
Just did a boost leak test and found both blow-off valves were leaking bad, throttle body was leaking good and the compressor housing on the turbo is leaking. So we are going to put the cam gears on and fix all the leaks than re dyno her and see if we can hit over 700whp
\It would be awesome if we could push 700whp on E85
Old Feb 18, 2007 | 03:11 PM
  #54
Here is the link to the dyno pull
http://www.youtube.com/watch?v=wLtbaxoMu9s
Old Feb 20, 2007 | 09:03 AM
  #55
jmartinez1170's Avatar
Im still waiting to see a stright E85 pull see what we get. Forget about the C16.
Old Feb 20, 2007 | 04:48 PM
  #56
Were doing a straight E85 pull Thursday night Going to push till we see some knock.
Old Feb 20, 2007 | 05:51 PM
  #57
Sharkbite2000's Avatar
Very Very Nice i wish i had the Green gas my way , Great Job on saving the earth
Old Feb 20, 2007 | 05:53 PM
  #58
I still love the smell of C-16
Old Feb 20, 2007 | 05:57 PM
  #59
We all do but at 10 bucks a gal. the C16 can stay right where its at.
Old Feb 20, 2007 | 05:59 PM
  #60
Your going fast and saving the earth and us, from the terroist that profit off the oil.
I'm going that route the minute its avaliable out here.
