05 MR Drive fluids confirmation
Old Feb 14, 2007 | 11:28 PM
grenade's Avatar
Just confirming the list.
Changing out the clutch, so Transmission, and Transfer Case fluids are being changed.
Transfer Case - Diaqueen (MR type) .58 qts
Tranmission - Bg Syncroshift 2 2.9qts.
Is this correct? Im so damn lost after searching the forums for the last few day's. I cant seem to keep a straigh answer in my head. TIA.
Old Feb 14, 2007 | 11:37 PM
Warrtalon's Avatar
No, don't use BG.
1) T-case and Rear diff = DiaQueen LSD Oil. It's not MR type...it's for all Evos
2) Trans = Super DiaQueen GL-4
3) ACD = Diamond SPIII ATF
Get the first two at Mitsubishiparts.net and the ACD fluid should be in stock at your local Mitsu in a 1qt container.
Old Feb 14, 2007 | 11:47 PM
grenade's Avatar
No, don't use BG.
Bah.. Not what I wanted to hear.
Ok. Thanks warrtalon.
Old Feb 14, 2007 | 11:50 PM
Erik@MIL.SPEC's Avatar
I haven't gotten it tested yet, but the MOPAR full synthetic looked real good when I had it taken out last weekend. It's an exact equivalent to the stock 75W-85.
You may also want to consider putting Redline Heavy Shockproof in the TC. Up until this weekend, I had only put stock fluid in, but I din't like the shavings I was seeing.
Old Feb 19, 2007 | 07:26 AM
PessimiStick's Avatar
Does anyone (Warr?) know the part number for the Transmission fluid on Mitsubishiparts.net? I got the LSD oil, but I can't seem to get the transmission fluid to come up.
Old Feb 19, 2007 | 07:36 AM
Exciting News's Avatar
2.3 qts in 6 speed. My dealer has them in tins just like mitsuparts. you may luck out.
Old May 2, 2007 | 02:59 AM
Jakeg97's Avatar
or save some cash and buy through
https://www.evolutionm.net/forums/sh...d.php?t=231811
bbak11010
Nov 3, 2011 06:42 AM
czilla
Mar 28, 2009 10:58 AM
skred
Apr 1, 2008 02:54 PM
hpgirl
Sep 8, 2007 06:30 AM
4-BNGR
35
Jul 10, 2005 04:22 AM
