20G injectors
Old Feb 18, 2007 | 03:59 PM
DS-03evo's Avatar
20G injectors
What cc injector's would I need to run a 20g turbo?
Old Feb 18, 2007 | 04:55 PM
EvoTech's Avatar
660 will do it. You want the smallest injector that you can get to run a around 85% duty cycle at max boost.
Old Feb 18, 2007 | 05:25 PM
DS-03evo's Avatar
Should I go with a certain brand, or whatever I can find for the cheapest?
Old Feb 18, 2007 | 05:47 PM
SWOLN's Avatar
660's if you are just running pump gas, but if later you run c16 or meth you'll need bigger. IMO 720's
Old Feb 18, 2007 | 05:56 PM
joeMama's Avatar
I have 720's in preparation, but 660's will be fine.
Old Feb 18, 2007 | 06:01 PM
Sgt Blamo's Avatar
I would buy my injectors from either of these two Evom vendors:
http://www.buschurracing.com/
or
http://www.extremepsi.com/store/cust...Fuel+Injectors
I'm going with 880's, but I have an EMS, you should go with at least 720's depending on your mods.
Old Feb 18, 2007 | 06:02 PM
Ultimate CC's Avatar
if you run meth all the time you will likely not need injectors...
Old Feb 18, 2007 | 06:07 PM
whitey4d's Avatar
Umm... Need you run Meth/Alky inj. or race fuel you actually need less injector not more. Especially so with the Injection kits.
Old Feb 18, 2007 | 06:11 PM
whitey4d's Avatar
I would say either 660 thru 750 sould be fine with a flash. If your going to be running 91 oct then you should lean towards a slightly higher flowing set up. I think that 660 would do fine.
Old Feb 18, 2007 | 06:14 PM
EvoTech's Avatar
98% of injectors are made by about 3 manufactures. Other companies like Buchur just put their name on them.
Old Feb 18, 2007 | 06:18 PM
DS-03evo's Avatar
This will be on 93oct, no race gas. It is my daily driver.
Old Feb 18, 2007 | 06:32 PM
Ted B's Avatar
650s are fine for you.
Old Feb 19, 2007 | 01:39 PM
DS-03evo's Avatar
Do you know who makes the Buschur injectors?
EvoVIII03
22
Feb 23, 2011 06:50 PM
4G63 T
Dec 4, 2010 12:36 PM
erggy
Oct 4, 2008 06:19 AM
deadbeatrec
361
Mar 6, 2006 02:46 PM
The442GTO
12
Feb 19, 2006 05:58 PM
