Is this my transfer case? Decel noise
Old Feb 18, 2007 | 07:41 PM
Vapor's Avatar
on my 03 GSR, i get a noticeable whine, only on decel. It will do it anywhere up above 30 mph, whether the car is in gear or not. I have 45k miles and the fluids have not been changed. I am installing a clutch/flywheel in a couple of days and
will be obviously changing all the fluids then, but i need to know whether i need a new TC or not. I searched extensively but couldn't find any posts that sounded like mine.
Thanks for the help
Old Feb 19, 2007 | 08:43 AM
Vapor's Avatar
anybody?
Old Feb 19, 2007 | 08:45 AM
whitersevo's Avatar
I think that would be normal, I would worry if you heard it when you are driving normaly, and it gets louder and louder..
Old Feb 19, 2007 | 09:25 AM
Vapor's Avatar
thats the thing, it has progressively gotten louder, and after reading so many stories about TC's I'm a little gun shy.
Old Feb 19, 2007 | 09:27 AM
whitersevo's Avatar
^^^^ well if it is going, it is going.. nothing you can do about it so dont worry, I would just start saving for a new one.. anyways, also usualy when they go out from what I have heard it sounds like a really loud siren..
Old Feb 19, 2007 | 09:32 AM
19psi's Avatar
I am pretty sure your tc is going out.
If the whine gets louder as time goes by...more than likely it's your TC.
Time to save up for a visit to Shep racing.
Good luck.
Old Feb 19, 2007 | 10:18 AM
Vapor's Avatar
Good luck.
i was hoping to hear more "change your fluids it will go away" responses
Old Feb 19, 2007 | 10:36 AM
19psi's Avatar
BTW, when was the last time you changed your fluids.
If it's been more than 15k since the fluid change, I would change it with proper fluid.
While you're at it, check to see if you see a lot of metal shavings on the magnetic drain plug.
Old Feb 19, 2007 | 10:41 AM
Vapor's Avatar
since i owned the car Bought it with 20k on the clock and supposedly the trans was serviced just before that. I'm now on 45k miles
I miss the days of owning my own lift, i was so much more diligent on keeping up with my service intervals
Old Feb 19, 2007 | 10:44 AM
scottatyamaha's Avatar
Well I dont think the TC has ever been touched with a fluid change because it is not recomended until 30k. I would change your fluid since most likley you are 15k miles over due.
Old Feb 19, 2007 | 11:08 AM
dubbleugly01's Avatar
change your fluids and see if it helps prior to the clutch job. If the noise goes away, no need to do anything different during the clutch install. If you still have the noise, then you'll still need to make a decision on what else to do.
25k on the tranny fluid and 45k on the t-case, ouch! Make sure you use the stock fluid (diaqueen) in the t-case when you change it.
EvoEarl05
Lancer Tranny/Drivetrain Tech
Jun 15, 2017 08:58 AM
dRifT iT
28
Jun 13, 2010 11:38 AM
TheeVOoNE
AEM EMS
Dec 20, 2009 08:03 AM
toovira
31
Sep 1, 2008 09:08 PM
MyEvoRocksUrv8
10
Feb 22, 2007 10:28 PM
