tricking the o2 sensor with catless exhaust??
im thinking about to install a testube to get rid of the stock cat. (yes i know its not leagal). i herd that it also throws a check engine when you do so?? is there like a extensions you put on the o2 sensor after the cat so it does not read as much??
You can use spark plug foulers to do that, or you can do what i did and get an ultimate racing test pipe,no cel guaranteed!
https://www.evolutionm.net/forums/sh...ght=mechanical
This is what I did, works good, never had a check light.
I too have the UR test pipe. Only thing I dont like is that you have to extend the o2 wiring so its not easy to reverse or 'hide' when you have to do a temp return to stock. If ya know what I mean.
woshi6mang
Evo X How Tos / Installations
22
Oct 28, 2009 08:53 AM
jerrymldz
12
Oct 13, 2007 08:22 PM
