cammed evo, slow?
Old Feb 28, 2007 | 08:42 AM
  #31
MFactor's Avatar
Originally Posted by playmajohn
naw man, raced a speed 3 the other day. i was suprised, he had boost controller/exhaust and something else and kept up top end. i should have been gonnnee
Unless you guys were racing from a dig you really shouldn't be surprised that a speed 3 can keep up at the top end. FWD > AWD on Drivetrain loss. Especially if he's modified.
Old Feb 28, 2007 | 10:21 AM
  #32
1_900hustler's Avatar
sorry to hijack this tread but quick Q.... if i upgrade to a 20g without cams , would it b a bad idea or would i be hurting anything etc... just gimmie the good and bad thanx
Old Feb 28, 2007 | 10:35 AM
  #33
Lancematic's Avatar
Like people have said before, how did you expect to make power on the cams without tuning for them? You had a base flash which is designed for a non camed car. TT is a great shop and know what they are doing. However, you can not expect them to have a tune be perfect when they don't even have the car in their shop. Every car is different, even if they have the same parts, and because of this a mail in flash will not work the same for everyone. Bottom line, if you want to make power you should have your car custom tuned or AT LEAST tuned to the parts you have on the car.
TT keep up the good work.
Old Mar 26, 2007 | 07:06 PM
  #34
davidevo's Avatar
I think is the boost leak, or you race too much ahen the car under first 3000 mile may cause the power go down.
Old Mar 26, 2007 | 07:13 PM
  #35
AL Beans's Avatar
tell him mark......... TT and the guys there are superheros...........and never mind those ignorant comments they just hate cause they are slow
Old Mar 26, 2007 | 08:27 PM
  #36
kaonashi's Avatar
You know i posted this along time ago also, basically the same thing happened with me and my friend, i could hang right next to him and all i had was i/e/mbc and he had i/e/mbc/fp/flash/ gsc272's
ended up being his cam gears were set off after he changed them he pulled like a ****. might wanna check into that.
Old Mar 28, 2007 | 01:24 PM
  #37
Sean03Evo8's Avatar
it depends on what brand of mods u chose and how the tune went..what did u put down?
Old Apr 29, 2007 | 02:08 PM
  #38
playmajohn's Avatar
alright so here i am agian, and now i have a LICP and got a a custom tune from AMS. car is alot more stable throughout all powerbands, but i am still not pulling as hard as everyone says. i raced my friend agian with intake/exhaust/boost controller, and i am still not pulling on him. sounds like i cant drive right? wrong we switched cars and its the same thing.
so heres what i think im going to do. i am still on stock clutch so im probably going to go with a $800 carbonetics or something. get a boost leak test, and get new cam gears. i really dont know whats up, but just wanted to clear up this thread after i got my tuned. do you think its my stock clutch that cant hold my power or what? i am also going to get dynoed, and post that up.
yes i do have a testpipe.
what cam gears yal suggest? i have hks 272s
Old Apr 29, 2007 | 02:10 PM
  #39
playmajohn's Avatar
also just to show where i am. i raced the new 3.5 350z today with just a drop in filter. mother****er kept up.....
Old Apr 29, 2007 | 09:36 PM
  #40
bluepeartype-s's Avatar
Registered User
I'm running 272's and no problem with my stock clutch at all...sounds like you got a leak...cam gears arn't necessary....
Old Apr 30, 2007 | 03:17 AM
  #41
2003raptor's Avatar
after all the replies, have u tested for boost leaks? thats a major thing. not something u should skip.
Old Apr 30, 2007 | 07:13 AM
  #42
Luis@TTP's Avatar
a untunned cammed evo should be pulling away from a tbe and boost controller on a evo the stock clutch has nuthing to do with this i used my stock clutch to get to12.3.
Old Apr 30, 2007 | 07:21 AM
  #43
scottatyamaha's Avatar
Have you verified that your cams are timed right? They could be a tooth off. If you dont know how to check this PM me and I will tell you how.
byebyesubbie
40
Sep 15, 2016 06:25 AM
sonic_evox
Jun 12, 2016 01:20 PM
travestyevo
Apr 3, 2009 08:51 PM
deegaw11
Nov 8, 2007 05:19 AM
EVOfunk
57
Nov 11, 2005 10:08 PM
