How much preload on Forge WG Actuator?
Old Feb 21, 2007 | 01:36 PM
kouzman's Avatar
Saturday i will install my Forge wastegate actuator along with some other parts. Currently i am boosting 23psi spike falling to around 17psi at the Redline...
How much preload should i put on the WG? I am thinking 3-4 turns, after the regular fitment...
I know that i will have to close my mbc quite a bit after the install because of the much harder spring (stock 11psi, Forge 19psi)...
Any idea?
Old Apr 3, 2008 | 03:16 PM
recompile's Avatar
<resurrect>
I'm installing the green soon with Forge WGA... I used 3 full turns (6 half turns)
We'll see how it works out
Old Apr 3, 2008 | 04:13 PM
sparky's Avatar
Shameless: What are you using for boost control? What will your peak boost be?
Old Apr 3, 2008 | 04:35 PM
recompile's Avatar
I use the stock BCS with #65 pill.
On 93 pump only, I'm going to try to hold 25 across the board.
On C16 I'm going to run 30 and I believe the Green will taper to 27ish at redline... but we'll see what the Forge & stock BCS can do
mityaz
Jul 5, 2017 06:22 AM
MyronGainz
58
Feb 2, 2017 08:21 AM
TommiM
Aug 19, 2014 04:54 PM
Evo8uk
Jun 1, 2011 11:43 AM
