Best header for stock turbo???
Old Feb 26, 2007 | 03:57 PM
  #46
sONE_SR's Avatar
Full Race if is not problem for your wallet !
Old Feb 26, 2007 | 04:13 PM
  #47
RanEvo's Avatar
Originally Posted by AfireINSIDE
Full Race IS a incredible piece and has been proven by Buscher to be the only mani make gains but not much over a ported and coated stocker............ And is costly
That's was the old design of Full-Race, now they came with new design which I have on my car
Old Feb 26, 2007 | 04:15 PM
  #48
ries's Avatar
personally Id suggest you go w/ a ported and coated stocker but if I had to choose from the choices you gave Id go w/ full-race....lifetime warranty - you cant beat that plus they engineer all their parts for best performance
Old Feb 27, 2007 | 02:08 PM
  #49
extreme evo's Avatar
thanx for infos..ı bought jic headers for my car..ı will post the dyno results as fast as ı do..
Old Feb 27, 2007 | 03:07 PM
  #50
futurevowner's Avatar
i think the best is full race if you want to spend the dough, otherwise ported stock
Old Feb 27, 2007 | 03:16 PM
  #51
evolucion9's Avatar
is there any point in coating it besides making it look better?
Old Feb 27, 2007 | 03:19 PM
  #52
Lancerguy'03's Avatar
they coat it with Ceramic i would imagine, that keeps heat down in the engine bay... what is the AVG cost ppl pay for porting the stock mani?
dont need to coat cause i got a friend that has a **** load of heat wrap.
Old Feb 27, 2007 | 03:25 PM
  #53
supposedly something it helps with heat but idk
Old Feb 27, 2007 | 03:28 PM
  #54
hamx0r's Avatar
Originally Posted by CBRD
if u want tubular, and dont want to spend a fortune, the megan works well.
keep the shield in the hood vent, dont heatwrap it, and it will be fine.
cb
why not heat wrap it? mine is heat wrapped and works fine.
Old Feb 27, 2007 | 03:47 PM
  #55
AfireINSIDE's Avatar
PPI is $65.00 for just the port, coating is used to keep the heat inside the mani to keep it moving faster the way its supposed to
Old Feb 27, 2007 | 03:59 PM
  #56
LoRo's Avatar
dc sports
Old Feb 27, 2007 | 04:59 PM
  #57
XK120's Avatar
general consensus is that heat wrapping can trap in moisture and salt (if you live in an area that gets salted during the winter). Basically it will eventually eat away at your manifold.
Old Feb 27, 2007 | 05:01 PM
  #58
XK120's Avatar
Keeps the heat where it's supposed to be. Also keeps engine bay temps down which is a good thing. Here's a good read with more info on Swaintech coatings
Old Feb 27, 2007 | 05:03 PM
  #59
hamx0r's Avatar
wow, i guess you learn something new everyday lol. but this shouldnt be a problem if it was tightly rapped with clamps at the ends right?(mine was)
Old Feb 27, 2007 | 06:07 PM
  #60
XK120's Avatar
It still could be a problem. Water can seep through. Water's a b1tch, finds its way into everything.
