6sp transmission case question
Old Feb 22, 2007 | 06:57 PM
grenade's Avatar
When re-installing the transmission back to the block, if there's about 1 1/4 inches left between the bellhousing, and the block, is that safe to assume that the input shaft is in the clutch ?
I have gotten the shaft into the clutch disk from what i can see, but it will not go on any further.. there's just over and inch left to go, and it will not budge.
Anyone got any tips?
6speed trans.
Old Feb 22, 2007 | 07:03 PM
94AWDcoupe's Avatar
No you cant take the case apart for install. The trick is to swing engine forward to allow easier in and out.
Old Feb 22, 2007 | 07:04 PM
grenade's Avatar
Swing the engine forward hrm..
Im going to go take a look at this. brb
Old Feb 22, 2007 | 07:41 PM
grenade's Avatar
Can I take off the shifter cable bracket on the top of the trans? This is whats holding me up... Anyone know?
Old Feb 22, 2007 | 08:04 PM
grenade's Avatar
Got the trans in closer, but now it wont go the last 1.5 inches
Old Feb 23, 2007 | 07:55 AM
grenade's Avatar
Anyone?
Old Feb 23, 2007 | 08:54 AM
94AWDcoupe's Avatar
yes you can take that off.
Old Feb 23, 2007 | 12:54 PM
grenade's Avatar
Yes, I took this off, but not out, i was able to swing it around to get the trans in more..
Now im stuck on the input shaft..
Old Feb 23, 2007 | 01:00 PM
fromWRXtoEVO's Avatar
send a pm to rraulston, he has done a few MR transmissions.
Carlos
Old Feb 23, 2007 | 04:00 PM
grenade's Avatar
Carlos
Will do, thanks
Old Feb 23, 2007 | 07:15 PM
Tim@AMSperformance's Avatar
did you use an alignment tool?? If not the clutch disc may not be lined up correctly.
Old Feb 23, 2007 | 07:26 PM
monies41's Avatar
the bracket satsy on. just take the downpipe off and PULL i mean PULL the engine forward nad put a piece of wood in there to keep it there and you will have enough clearence. We did mine last week
Old Feb 23, 2007 | 07:41 PM
hondafan's Avatar
try putting a socket/ratchet on the crank pulley on the other side of the engine and turn it a bit till the splines of the disc and input shaft line up and it should slide on.
Rom
Feb 20, 2017 11:48 PM
Jonno99
Aug 7, 2016 04:51 PM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
TomekEVO
Oct 18, 2015 07:48 PM
aedubai
13
Oct 5, 2009 02:17 PM
