Transfer case???
Old Feb 28, 2007 | 05:49 PM
MyEvoRocksUrv8's Avatar
Transfer case???
Ok so I've been reading alot in threads that if you hear a whining noise coming from your car it is probably your transfer case going out. Well....my car makes a slight wining noise, not really loud, and mostly just in 3rd and 4th gear. I just got a clutch/flywheel installed and im pretty sure they used the right t-case fluid. Do you think this is my t-case going out or is this just normal?
Old Feb 28, 2007 | 06:32 PM
Anyone?
Old Feb 28, 2007 | 06:34 PM
smokedmustang's Avatar
More meat in the potatos please! Mine blew out 200 miles after a clutch job. go get on it, and see if it gets louder about 70-80, in boost.
Old Feb 28, 2007 | 06:35 PM
4TUN8's Avatar
It's going I bet.
Old Feb 28, 2007 | 06:41 PM
Kdash106's Avatar
mm. my car has 6000 miles on it, it whines when i let off the gas to slow down.. does that mean mine is going out too?
Old Feb 28, 2007 | 06:45 PM
dubbleugly01's Avatar
some gear noise/whine is normal. The "death whine" most people talk about of a bad ring/pinion (commonly called a bad t-case) occurs at freeway speeds. If it is gear dependent and not speed dependent, it's probably just normal gear whine. If it's speed dependent, it's probably the ring/pinion.
Old Feb 28, 2007 | 06:46 PM
no, decel gear noise and whine are normal.
Old Feb 28, 2007 | 06:48 PM
Kdash106's Avatar
so if it whines when your in gear and on freeway going like 60-80 than its T-case?
Old Feb 28, 2007 | 06:52 PM
Sap12687's Avatar
FWIW, mine went after a clutch install as well. Started to whine in 3rd and 4th and got fairly loud up top in the RPM's.
Old Feb 28, 2007 | 06:56 PM
Evoryder's Avatar
my TC started to whine a month after doing my clutch....my fault..didn't put the oem fluid in it. Live and learn...i'm still riding with a whining TC ...don't launch the car, don't feel the urge like i used to before changing the clutch.
Old Feb 28, 2007 | 07:00 PM
yes, but the whine will be unmistakable...... loud as hell, and you will without a doubt know something isn't right
Old Feb 28, 2007 | 07:01 PM
Evoryder's Avatar
definitely noticeable and distinct ....
...constant...and then goes away at certain speeds "wwwooOOOOOOOOOOMmMMmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmm"
Old Feb 28, 2007 | 07:07 PM
SWEEEEET - It sounds liek it is just normal then, cause it is fine on the highway and highspeeds, and its not that loud. Thanks a lot guys for your help once again!
Old Feb 28, 2007 | 07:08 PM
Oh, and just in case I ever need to replace the transfer case.....what is the cheapest way I could go? Do I have to buy a new one...or could mine just be rebuilt. How much did it cost you guys that had to replace it?
Old Feb 28, 2007 | 07:25 PM
Kdash106's Avatar
i heard shep (sp?) can rebuild it.. i don't know the site for it.
