Front motor mount + side motor mounts = less vibration?
Old Jan 2, 2013 | 02:31 PM
  #31
johnnnyjeans's Avatar
Originally Posted by elim0
can you report back after you've done more driving and worn the side ones in more. i think when i did my front one i noticed it wore in after maybe 500km.. and you said the front one was 500miles for you, maybe the side ones are roughly that amount too ?
i said the sides are in for 20 miles. This is the second time i've answered this. LOL
Originally Posted by Tom Stout
he said to report back once your sides have about 500 miles on them
I never said I wouldn't. you people just dont read these days. but its ok. i dont read either.
i will report back after 500 miles. I am currently at 200miles. NO CHANGES. VIBRATES like a BIATCH.
My right headlight shakes so much it might as well fall off.
Old Jan 2, 2013 | 02:32 PM
  #32
does your right side headlights vibrate like crazy? and i nkow nothing's lose. and the exhaust drone gets way louder as it is transfered into the cabin space. ???
Old Feb 10, 2015 | 12:34 AM
  #33
ace33joe's Avatar
Bringing back the old thread:
Had Powerflex front (road use - yellow) engine mount bushing for a while - increased vibration over stock but definitely less engine movement.
Ordered two Powerflex side (also road use - yellow) mount bushings and installed only one at the passenger side (near cam cover) - no more noticeable vibration, but definitely can hear more drivetrain sound (I wouldn't call it noise because it is not bad to hear them more).
I couldn't lower the tranny side (driver side) enough to take out the stock mount, and the bushing looked clean, so I left it stock, but I think I made a good choice.
Passenger side (cam side) bushing already had multiple cracks on the surface (03 EVO, 43k miles, ~5 track days per year), so I guess it gets more stress than the driver side.
Also it makes sense that mounts that are closer to driver side make "driver" feel more vibration and noise, so if you prefer minimal increase in NVH, leave rear / driver side (tranny) mount stock.
Of course, you will have less "solid" feel in return, but it would be a good compromise for DD cars.
I am thinking installing new stock mounts on those two old mounts when I do clutch install later instead of using aftermarket ones.
Old Feb 10, 2015 | 08:52 AM
  #34
mrfred's Avatar
you make me want to inspect my side mounts.
Old Feb 10, 2015 | 08:59 AM
  #35
voodoo-wrx's Avatar
Replaced the passenger and transmission side this past weekend. The AMS mounts that I had in before were pretty bad (in the car for about 6-7 years). Went with Torque Solutions and it did reduce the vibration.
Old Feb 10, 2015 | 03:27 PM
  #36
ace33joe's Avatar
Passenger side one is easy to check, but driver side requires removal of battery cover or inspection mirror might work.
Since your EVO is so much higher power, might be a good idea to check if still stock.
Powerflex yellow is 70A, and AMS black should be the same, and TS is 75A, which all should be acceptable for DD.
gt420hp
17
Sep 10, 2020 05:13 AM
kwinters
Lancer Tranny/Drivetrain Tech
10
Nov 16, 2017 04:20 PM
StephenMcC56
May 17, 2017 09:48 AM
remusrm
Dec 2, 2016 02:57 PM
Turbo_Saloon
Sep 30, 2010 02:20 AM
