help me reach 400+hp or more
Old Mar 3, 2007 | 09:44 PM
evilevo2006's Avatar
ok well im getting tuned in 2 weeks. my mods are
2003 evo 8
3''tbe 'with test pipe'
o2 housing
ported 10.5 hotside
ported stock manifold
hks rs intake
aps bov
fmic
u/l icp's
ARP head studs
forge waste gate
forge mbc
revolver cams springs retainers
cam gear's
meth kit running 100% meth
exedy twin HD
bpr8es gaped to .025
walbro 255 f/p
gas i will use is 93 oct
i think thats most of it.
looking for small fast mods to add that might help me reach my goal.
what else can i add to my setup to make and or brake the 400hp mark?? thanks guys for the tips and info. all idea's are welcomed.
Old Mar 3, 2007 | 09:51 PM
Ultimate CC's Avatar
nitrous haha...depends on the dyno though, if they mess with setting you can have any number you want...your car looks to be a high 11sec car once tuned...
Old Mar 3, 2007 | 09:54 PM
well without the cams meth gears i ran 12.2 at 113mph with a 1.8 60foot.
this was a flash that was logged and then tweeked not a custom tune like im getting. and i think im getting dyno tuned on a mustang dyno.
Old Mar 3, 2007 | 09:55 PM
EVO8904's Avatar
I think you should get 400
Old Mar 3, 2007 | 10:14 PM
MRevolutionRed's Avatar
there is no way you will see 400 whp on a mustang dyno. i dont even think you will see 400 whp on a dynojet.
Old Mar 3, 2007 | 10:23 PM
thisxguy's Avatar
you'll want a fuel pump and injectors
but you're not going to hit 400 with those mods
what TBE is that? ...brands do matter.
you'll need a bigger turbo
fyi...ported stockers dont give the best air flow
Old Mar 3, 2007 | 10:27 PM
sparky's Avatar
AEM EMS( tuned by D.B.), P&P head, 20G-LT, Full Race header and C16 on a Mustang Dyno, along with your listed mods, should break 400, even w/o drugs.
Old Mar 3, 2007 | 10:32 PM
there isa mod i forgot. i have it and forgot to add it.
its a works 3 d/p custom 3 d/p back.
Old Mar 3, 2007 | 10:33 PM
lol i said small mods. not a new setup. the goal is 400hp on stock turbo. lol.
Old Mar 3, 2007 | 11:01 PM
bchang's Avatar
Meth?
Old Mar 3, 2007 | 11:03 PM
Originally Posted by bchang
Meth?
got it. 100% meth. should be on the list already
Old Mar 3, 2007 | 11:09 PM
sparky's Avatar
If you want more than 400 WHP on a Mustang Dyno, with the stock turbo and ECU/MAF, and on pump plus meth, you'll probably need a righteous tune, and lots of boost(like 28#+). At which point the stock turbo will just be blowing hot air. And I don't know if you can get the full benefit of the Revolvers on a flash, and through the stock ports. But good luck...... and at least, do the headstuds, and while you're at it, drop the pan and do the rodbolts to avoid walk..
Old Mar 3, 2007 | 11:12 PM
If you want more than 400 WHP on a Mustang Dyno, with the stock turbo and ECU/MAF, and on pump plus meth, you'll probably need a righteous tune, and lots of boost(like 28#+). At which point the stock turbo will just be blowing hot air. And I don't know if you can get the full benefit of the Revolvers on a flash, and through the stock ports. But good luck...... and at least, do the headstuds.
lol another mod i forgot. head studs.
my tuner said he will try to tune it on a spike of 28psi. so i guess i am just spiking 28 for a sec but then droping and tapering from there.
Old Mar 3, 2007 | 11:14 PM
and its not that i want it on that dyno. i just want the car to have it but i would not mind a paper that show's it. get my point a little better?
Old Mar 3, 2007 | 11:20 PM
sparky's Avatar
Evil, I'm just busting your *****. I'll bet you should get pretty D**n close to your goal. I just think that the stock turbo and MAF will be the limiting factors, as well as the pump plus meth. Maybe on C16 plus meth and 32#....At any rate, Good Luck!
