Head specification
Old Mar 5, 2007 | 12:23 PM
sabastian458's Avatar
Head spec Question
Hey, I have been searching through a ton of useless threads looking for the piston to valve clearance for a factory pistions and valves. I need to know if I have a virgin block and I have the head milled 15 Thousandths, do I have enough clearance with the factory head gasket? Please, if all you can answer is get a thicker gasket, dont answer. Thank you all if you can help.
Old Mar 5, 2007 | 01:56 PM
Anyone?
Old Mar 5, 2007 | 02:19 PM
brute_nm's Avatar
I've had my head decked twice and I run the an OEM FelPro or similar head gasket. I'll get compression numbers soon, if you're interested.
Old Mar 5, 2007 | 02:43 PM
How much did they take of each time? and the compression #'s would be wonderful, thank you tons
Old Mar 6, 2007 | 05:58 AM
bump. . . Some one has to know how much can be saftly taken off a head.
Old May 28, 2007 | 05:10 PM
jkim2001's Avatar
bump for an answer as well.
Old May 28, 2007 | 05:19 PM
ak47po's Avatar
From the Mitsubishi service manual.
Old May 28, 2007 | 05:48 PM
jkim2001's Avatar
thanks!
Old May 28, 2007 | 05:54 PM
ak47po's Avatar
Originally Posted by jkim2001
thanks!
No problem.
Old May 28, 2007 | 07:10 PM
jkim2001's Avatar
so the machine shop removed 0.7mm off my warped head. No go? New cylinder head instead? What difficulties might I encounter if I went and installed it?
Old May 28, 2007 | 08:07 PM
Aby@MIL.SPEC's Avatar
you should be fine.
especially since people run 11.4 mm lift cams & dont have v/p issues. that is a ~0.030" or ~0.75mm more lift than a hks type cam.
if your super concerned, you can run a thicker head gasket to make up for the differnce, then you'll get less performance from the engine due to the reduction of squish area / greater clearance between the outter portion of the cylinder head & piston.
