Forge MBC Users -how much psi increase per click?
Old Mar 30, 2007 | 08:14 PM
mudduck's Avatar
Originally Posted by sabastian458
.5 psi per click. At least with the last two I used that is how much it was.
Yeah, this is also what I have seen: 2 clicks = 1 psi
Old Apr 2, 2007 | 07:54 AM
boomn29's Avatar
Originally Posted by Mike@Forge
This is a very close approximation of what we have typically seen as well.
There is no set increment, however, so it will take some trial and error to dial in specifically to your car.
How high can we get the boost with the delivered softer spring? I was seeing ~18-19psi in 3rd and I was going to knock it up a bit and I found I was at the max!
I'm thinking I need to switch to the stiffer one and back it way down.
Old Apr 2, 2007 | 08:27 AM
TonyG's Avatar
x2
I'd like to know this too.
Old Apr 2, 2007 | 09:59 AM
Mike@Forge's Avatar
There is no set number for that either.
Your range of adjustment will be based on the base spring pressure of the wastegate actuator or external wastegate you are currently using. Stock, ours, FP, Buschur, etc., or even an external wastegate.
Even if you have a stock actuator, it could be adjusted differently from your buddy's car.
It's all trial and error.
First, run the car on just wastegate pressure. Adjust and dial in the wastegate if necessary.
Then add the boost controller and make your adjustments until you reach your desired boost level..
brenner
35
Aug 25, 2010 10:05 AM
jxn evo 8
15
Apr 16, 2006 07:34 AM
AzBlackEvo8
18
Dec 29, 2005 09:02 PM
QuickEvo
15
Oct 26, 2005 03:38 PM
warp9
21
Sep 23, 2005 10:47 AM
