Boost problem please help.
Old Mar 19, 2007 | 08:54 AM
1BADEVO8's Avatar
Now I know there have been other posts on this and I have done a search. Even though I've read some other posts I havent seen a definative anwser to the problem.
Here goes, I have an 05 evo 8 mods in signature. The cars has been running fine up until a couple weeks ago. I used to be able to turn the BC on high or low and it would hold that boost regardless of how fast or slow I was going.
Now if the BC is in high or low the boost will build up normally and hold but only until about 5000-5500 rpms. After that it wants to keep going up and I dont really have the fuel system or a built motor to see how high it will go.
I have replaced the vaccum lines, tested the solenoid for function, and backed off the wga. These "quick fixes" have done nothing if anyone can help I would really appreciate it.
Thanks,
Jesse
Old Mar 19, 2007 | 11:39 AM
bigtymer's Avatar
mybe a fresh tune and a new wastegate will solve it
Old Mar 19, 2007 | 11:46 AM
jhanksevo's Avatar
+1
Old Mar 19, 2007 | 11:28 PM
1BADEVO8's Avatar
Thanks for the suggestions.
Old Mar 20, 2007 | 01:06 PM
ElectricEvoIX's Avatar
boost leak test? check the upper intercooler hose by your throttle body that's where I had my problem. I would get good boost till 3600 and then it would slowly taper off meaning I was losing power across the powerband
nspyr
26
Jun 20, 2017 02:08 AM
mattz09
Apr 11, 2010 08:55 AM
Spinsall4
Mar 23, 2009 11:24 PM
U2SLO
61
Dec 20, 2007 09:09 PM
Tuner@Swift
26
Feb 8, 2007 05:18 PM
