can i run the stock ecu with a walbro fuel pump??
ok i need to get my 5th gear warranteed. so the car is tuned on the safc2. i plan to put the stock fmic, stock pipes, stock exhaust, stock intake, stock bov, stock cams, stock injectors
will the stock ecu run the car fine with the walbro cuz i relly dont want to swap that out.
the Mitsu technician is going to clue in immediately on the fuel pump and void your warranty, and you're gonna have to pay out of your pocket to fix you're broken transmission.
Or at least that's the way it should work.
Thanks in advance for modding your car and trying to return it to stock, and then expecting Mitsu to fix it under warranty, and making us all suffer in the long run.
Only other way they can tell is cause it's loud as hell and then they'd have to know what the sound is. Unless you know already I doubt the tech would even think about it.
the fuel pump broke his tranny?
Your ECU is already stock.
