Fuel pump ??'s
Fuel pump ??'s
ive noticed that almost everybody on the forums has upgraded to a walbro fuel pump but my question is (remember im a newb so be nice lol) why? i mean i know to push more fuel but how unefficient is the stock one? also how far can the stock injectors go before you have to upgrade them to? im just tryin to understand a lil more cause im thinkin about ungrading to one but im also curious as to what kind of hp increase i would get with a better pump after i get tuned with it?? sorry for the newb question but the search wasnt helpin me much, thanks
A higher volume fuel pump keep air/ fuel ratios consistant by flowing more gallons per minute. 255 GPM.
Under wide open throttle, the injectors are squirting fuel, hopefully not using a 100% of their capacity. Fuel pressure drops if the pump cant feed the motor enough fuel under heavy load. Having a nice strong pump will keep up the optimal fuel pressure in turn making your tune, and the car run consistantly.
hopefully this will help you out with the evo 8 fuel pump deficiencies:
https://www.evolutionm.net/forums/sh...d.php?t=256499
i will be expanding this research as i am in the process of buying a better data aq system with more sensors.
