Interesting testing - cosworth cams - 100 octane fuel and test pipe tested Evo IX
I thought it was the opposite? IX's are NOT as prone to knock than the VIII's due to the extra cooling passages in the head.
The ecu however is more sensitive and will pull timing faster - particularly at high rpms
When you add the cams - the car picks up a lot of low end power but it is hard to make large gains up top (on pump gas) without seeing knock counts
I will post the final dyno numbers later this evening - the sheet actually came out really good
This is true - the engine itself and larger turbo make the car less prone to actual knock
When you add the cams - the car picks up a lot of low end power but it is hard to make large gains up top without seeing knock counts
Comparing the dyno to my IX tune w/o cams+cat, looks like the cams+TP added about about 30lbs torque and 500rpm and +10WHP. Thanks for sharing. It's helpful to know for my cams decision.
Final results
You can see that the car is making huge TQ and decent power - at a low boost level - the cams help you make great power without jacking up the boost as much
conversly with the cams IF you jack up the boost it can get more knock happy
I think the taper is better on the finished product
DynoFlash
126
May 30, 2008 02:43 PM
DynoFlash
34
Jul 4, 2007 08:38 PM
DynoFlash
80
Feb 19, 2007 02:41 PM
