Interesting testing - cosworth cams - 100 octane fuel and test pipe tested Evo IX
Ok - here is an interesting dyno sheet
This car was originally tuned with some minor parts like an intake and a flash - this is the black run 004
Some time later the customer returns and adds
Cosworth cams
Buschur full Stage II with high flow cat
Inclues T/B exhuast - Intake- lower fmic pipe - MBC - pump - 02 housing - flash
This is the red line - 009 - is the tuned pump gas reflash. I felt the car was on some real weak gas and it was having small knock counts even with a very conservative tune. I wanted to rule out any issue with the cam install - e.g. engine noise - (flase knock) etc so I poured in some 100 octane unleaded fuel
Run 010 green - nothing changed - just the 100 octane fuel - the car goes 100 % knock free and holds timing
Next - we felt that the high flow cat may be the culprit holding back the power so we drianed the 100 octane fuel out and then we got some fresh pump gas and installed a test pipe
Run 011 is the run with pump gas and the test pipe - No tuning of boost changes
I thought this was an interesting dyno comparision
I then retuned the car and it was done
AL
Cosworth cams
AL
It is more like an exhuast restriction creates additional un-needed back pressure which results in ineffective exhuast gas evacuation fron the cylinders
This condition enahances the tendancy to knock
IX Evos are very senestive to knock
The TQ is fantastic but how come the power drops off so much after 6200? Shouldn't it be able to at least keep peak power to 7000-ish?
Also- as mentioned above the car was very knock prone
I think the final tune was flater - keep in mind this is a interim testing not the final tune
I will print off and scan the final dyno sheet later tonight
The main use of a dyno is to measure what happens between one run to the next
good job al as always
