Rear diff drain and fill
Old Apr 4, 2007 | 04:46 PM
mitsu IX's Avatar
Does anybody know a site that has pictures on how to change your rear diff fluid. I know there is a thread but I was wondering if there are any picture to go along with instructions.
Old Apr 4, 2007 | 05:15 PM
hondafan's Avatar
i don't know of one, but it's extemely easy to see the drain/fill plugs for the rear diff. if there's any specific question that you need answered to help you out let me know. the rear diff IMO is the easiest diff to change fluid in on the evo.
Old Apr 4, 2007 | 08:14 PM
barneyb's Avatar
Remove the fill plug
Remove the drain plug
When drained replace the drain plug
Add fluid until it runs back out of the fill plug opening.
Replace the fill plug
Old Apr 4, 2007 | 08:21 PM
AF-Evo8's Avatar
+1 its definately that easy
Smike's Avatar
http://www.socalevo.net/forum/index.php?topic=2682.0
and you are welcome
Old Apr 4, 2007 | 08:28 PM
mathgeek's Avatar
The rear diff is indeed the easiest to change. If you want to know where it is, just crawl under the back of your car. It's a little ways under and in the center. You'll notice a 24 mm drain plug at the very bottom of the differential. Right above that, on the side, is the fill plug (17 mm). You can't miss it. I changed the rear diff for the first time a couple of weeks ago. I didn't even need to jack up the car. And make sure you use Diaqueen (my personal opinion).
Old Apr 4, 2007 | 08:29 PM
Links0000's Avatar
The one in the how-to section has pics if you go to the discuss thread here link
Old Apr 4, 2007 | 10:00 PM
wokuku's Avatar
How do people get that 17mm fill bolt out? I couldn't find a socket that is shallow enough to plug in.
Old Apr 5, 2007 | 04:16 PM
hondafan's Avatar
you could try a wrench.
MadBoostedEvo
Apr 19, 2015 07:51 PM
Majakelong
Mar 9, 2015 09:47 PM
fq400dave
11
Oct 29, 2013 01:49 PM
jojipoji
Dec 21, 2010 10:52 AM
nitz
Jul 22, 2008 01:10 PM
