AMS Ultimate Fuel Pump Test
Old Jul 1, 2007 | 08:21 AM
  #91
crcain's Avatar
Originally Posted by Ross W
Are you running a walbro in tank directly to the Bosch 044? or via a swirl pot?
No swirl pot. In tank Walbro direct to the Bosch 044.
Old Jul 1, 2007 | 08:32 AM
  #92
slowTsi's Avatar
After looking at it a bit and thinking about it, it seems the the intank would boost the output of the 044 by a lesser amrgin, as it is less effected by boost. It appears at a glance that the pumps are sharing the pressure in that fashion. AT 80psi, the 255/255 series has it flowing comporably to what the inline pump does at 40psi. Seems somewhat logical to me that the 255/044 combo will react simlarly and flow 307lph at 80psi.
Old Jul 1, 2007 | 08:54 AM
  #93
High_PSI's Avatar
Indeed, I concur.
Old Jul 1, 2007 | 08:56 AM
  #94
ExViTermini's Avatar
on the walbro pumps, what was the amperage draw at full tilt?
Old Jul 2, 2007 | 08:59 AM
  #95
slowTsi's Avatar
So is the rig still assmeble making this test possible(intank 255 and the 044 inline)? I can send you my 044 if you no longer have one available.
Old Jul 6, 2007 | 03:19 AM
  #96
CT-PR_Evo8's Avatar
I would like to see a 044 in tank feeding a 044 external
Old Jul 7, 2007 | 03:22 AM
  #97
slowTsi's Avatar
People have run the 044 successfully with just a syphon tube runnig down through the assembly with no feeder pump. There would be no point in buying a $220 pump to feed the 044 as you could just run both of them externally and parallel.
Old Jul 17, 2007 | 10:54 AM
  #98
TTP Engineering's Avatar
Excellent thread Martin.
Old Jul 17, 2007 | 06:26 PM
  #99
value's Avatar
Martin does the AMS 1000HP setup replace the return line back to the tank? Another thread by another vendor is saying the return line is to small to flow excess fuel back to the tank with upgraded pumps causing excess fuel at idle. Thanks for the test and hard work as usual
https://www.evolutionm.net/forums/sh...d.php?t=256499
Old Jul 20, 2007 | 01:33 PM
  #100
crcain's Avatar
Am I right in reading this that a modified Walboro 255 flows about the same as a Bosch 044 at 80 PSI? Surprised cuz the Bosch is a beast in terms of size compared the Walbro.
Old Jul 20, 2007 | 01:57 PM
  #101
l2r99gst's Avatar
AMS,
Did you get a chance to graph the 12V numbers or any other voltage numbers? If you don't have time to graph them, just post up the data or PM me with the data. Specifically interested in the IX fuel pump numbers.
Thank again for the great tests.
Eric
Old Jul 31, 2011 | 08:58 PM
  #102
ProPilot04's Avatar
I'm bumping this thread because it appears that the graph on the front page is missing and I'd like to see it.
I'm running the stock IX pump, looking to upgrade, have had a Walbro before, but would love to not have to listen to it.
Old Jul 31, 2011 | 09:11 PM
  #103
Mellon Racing's Avatar
we carry the DW 300lph and aeromotive 340lph pump which should out pace the walbro easily
Old Jul 31, 2011 | 09:20 PM
  #104
ProPilot04's Avatar
Both of those are on my short list. I've been following (or followed via search) the release thread for the DW... and ultimately, that'll probably be the route I go. I guess I'd just like to see some data from the testing they did.
I won't be doing anything serious... so I'm not sure I even NEED a fuel pump, but as has been mentioned... cheap insurance.
I'll be running (fwiw):
Cone Filter
Buschur TBE (no cat)
UICP
LICP
Using ECU controlled boost with a perrin EBCS
At least thats my plan. It's on a 9MR, and I don't really plan on getting much crazier than that. I want reliable (quiet fuel pump lol) performance... though, with the TBE... I'm not even sure I'd hear it.
Old Aug 2, 2011 | 08:53 AM
  #105
mrfred's Avatar
see page 5,
