Full Race Gt37 Turbo & Manifold - Dyno Sheet
Old Apr 9, 2007 | 01:43 PM
  #31
crcain's Avatar
RPM at 20 psi and RPM at 40 psi?
Am I being stupid asking for this? Is it pretty easy to tell based on the dyno sheet provided?
It would be cool if all people who posted sheets would also post sheets of AFR and boost. That would be cooool.
Old Apr 9, 2007 | 03:28 PM
  #32
DynoFlash's Avatar
The boost is undisclosed per my post above
Old Apr 9, 2007 | 03:36 PM
  #33
kmcconn9's Avatar
very impressive.
Old Apr 9, 2007 | 03:57 PM
  #34
crcain's Avatar
Man it's like pulling hairs around here to get info. If you go through the effort of posting specs, graph, fuel, etc.... why not give everyone an idea of when this turbo starts spooling and when it makes a decent amount of boost?
It makes sense to me why you might not want to disclose max boost... that is a bit of a trade secret as to where you think it makes the most power. But couldn't you give an idea of how it spools?
Old Apr 9, 2007 | 05:16 PM
  #35
EvO6-RS2's Avatar
Good Job AL....sweet power!!!!
Old Apr 9, 2007 | 11:13 PM
  #36
Frenchy4g63's Avatar
PS it should be also noted any more power and the customer needs 1200 injectors
108% duty cycle - the alchy is helping - but more injector is needed
Originally Posted by LilRico
YUP! That's exactly what DB said when I told him I wanted him to build my EVO using his BR GT67 P Trim Turbo Kit (37R). He said 1,000's could work, but he might have to go to 1,200's
1000cc injectors should be plenty for a "37r"
If you notice the only people having to use 1200's or 1600's on a "37r" are using the AEM EMS without the peak and hold injector driver. There's a car on here with a 4088r, putting out 730+whp on a Mustang dyno using 1000cc injectors, with room to spare. He is using a Motec EMS though.
It has something to do with the signal the AEM sees, the peak and hold driver corrects the problem. If you add that small part, you dont need huge injectors.
Old Apr 9, 2007 | 11:55 PM
  #37
LilRico's Avatar
Hmmmmmm......... Very interesting.........
Ang Wen Yan
348
Jan 8, 2017 11:50 PM
David Buschur
Mar 6, 2009 07:30 AM
DynoFlash
136
Oct 12, 2008 02:47 PM
DynoFlash
78
Apr 25, 2008 02:46 PM
gt40
19
May 20, 2004 01:19 PM
