Help!! Problems With Hallman MBC
Old Apr 8, 2007 | 07:15 PM
KcEvil8's Avatar
it should came with another spring that is stiffer then the one already inside the boost controller. that what happen to me when i installed mine and it only boost to around 12psi, even with the boost controller turn all the way. Then i switch the spring and everything is fine. If you going to switch the spring on the black one to the red one, make sure u turn the boost controller all the way down first.
Old Apr 8, 2007 | 07:42 PM
03evopa's Avatar
im having the same damn problem
Old Apr 8, 2007 | 08:53 PM
xLaNcErEvOx's Avatar
i actually things to do tonight, so ill test the springs tomorrow. hopefully everything works fine, if not i will have it shipped back out tomorrow.
Nauticabri
50
Jan 10, 2010 10:36 PM
elphalba
11
Jan 24, 2009 05:46 PM
avo3vom
15
Sep 11, 2008 12:45 PM
mscorei
Sep 10, 2007 09:20 AM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
