Acetone as Fuel Additive
Old Apr 9, 2007 | 04:17 PM
voidhawk's Avatar
Lightbulb Acetone as Fuel Additive
I ran across this article that claims adding acetone to your fuel improves atomization by reducing surface tension, thereby improving performance and power ouput.
http://www.pureenergysystems.com/new...00069_Acetone/
My friend tried this on a rental car and improved MPG from 31 to 36 (driving under similiar conditions). I have a can of acetone in my garage and am itching to try a before / after "dyno" (using an OBD-II scanner tool), but was wondering if anybody has tried this before?
Old Apr 9, 2007 | 04:25 PM
apevo8's Avatar
haven't tried this but do know that acetone is a VERY effective cleaner used on things that wouldn't come off with ordinary cleaner......if u do try this, post the numbers, maybe ill give it a shot
Old Apr 9, 2007 | 04:27 PM
apevo8's Avatar
this was part of an article on wikipedia......
Some automotive enthusiasts add acetone at around 1 part in 500 to their fuel, following claims of improved economy. The practice is controversial as acetone may affect fuel system parts, such as rubber seals. Reports of vehicles covering 50,000 miles (80,000 km) without fault[citation needed] would suggest that the percentage 0.2% acetone to fuel ratio will not adversely affect any parts, pipes, seals etc.[citation needed]
Old Apr 9, 2007 | 04:31 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I tried it and found all the claims about improved milage to be bogus. At the time I was driving 250 miles per day and it was very easy to test. I ran acetone for 3000 miles and didn't notice any difference.
Old Apr 9, 2007 | 04:45 PM
SlowCar's Avatar
do not put acetone in your fuel system. it is a very polar solvent, like MEK (pvc cement)...
Old Apr 14, 2007 | 11:08 PM
Saikou_kun's Avatar
I did a test on this too. I kept a close eye on mileage.
Results: total bunk
Driving habits affect mileage more than anything.
Last edited by Saikou_kun; Apr 14, 2007 at 11:08 PM. Reason: my grammar is teh lame
Old Apr 15, 2007 | 05:53 AM
240Z TwinTurbo's Avatar
1 gallon to Toluene per tank of 91 does the job. I used to run 25psi in my Z with this.
Old Apr 15, 2007 | 02:31 PM
But that is to increase octane and what the OP is talking about is 3 to 4 ounces per tank full to increase mileage.
Old Apr 15, 2007 | 02:41 PM
derangedazn's Avatar
Dont believe everything you read on that site.
Old Apr 15, 2007 | 02:59 PM
Correct, but what is the mechanism that would allow your engine to run more efficiently when using small amounts of Acetone?
Old Apr 15, 2007 | 03:05 PM
It's supposed to improve combustion. You can check out the website for more info. After finding it didn't help my mileage, I dumped in 1/2 a gallon on about 1/2 a tank and cranked the boost. Now that was fun.
Old May 12, 2007 | 09:38 PM
lemmonhead's Avatar
put feric chloride in your car, will run like a champ.
Old May 14, 2007 | 05:09 AM
honda-guy's Avatar
of all the test i've seen with good results, they were all done on carbureted engines. fuel injection already does a pretty good of atomizing the fuel.
ScorpiA
Lancer Engine Management / Tuning Forums
Sep 5, 2012 09:39 AM
ashun22panda
51
Apr 14, 2012 10:25 PM
eldanoloco
Jun 9, 2004 11:43 AM
