downpipe material. what to use
Old Jun 9, 2003 | 09:00 PM
w2pac12345's Avatar
I am planning on doing custom exhaust inclduing a downpipe. Can the downpipe be made of normal exhuast tubing or do I have to get special materiaL or do Ihave to buy a downpipe already made?
Old Jun 9, 2003 | 09:09 PM
MalibuJack's Avatar
Your best bet is to purchase one already made.. The research and development has already been done for you... Search the forums there is tons of info on your options. Most if not all of them are made of stainless steel.. and most are 3" diameter, with a few at 2.5"... Don't reinvent the wheel if you don't have to..
Old Jun 9, 2003 | 11:23 PM
w2pac12345's Avatar
not trying to "reinvent" I am trying to save money. My exhasut shop can mimick the bends of a downpipe already made for the evo with 3" mandrel bent exhuast tubing. What I was wondering was if the standard exhuast tubing would be thick enough to keep the heat inside the tubing or do I need thicker tubing since it is next to te exhuast manifold?
Old Jun 9, 2003 | 11:27 PM
HobieKopek's Avatar
If you get it done and find it's not sufficient, just remove it and heat wrap/seal it. Mine's stainless steel (not an evo, but same principle) but I'm not sure what grade.
Old Jun 9, 2003 | 11:28 PM
MalibuJack's Avatar
Standard heavy Stainless 3" tube would be adequate, probably something along the lines of what is used on a Bus.... The only things I'd be cautious about is the location of the O2 sensor bung, and use thick flanges so they won't warp.
Old Jun 9, 2003 | 11:29 PM
MalibuJack's Avatar
And don't forget to tell us how much it cost you, and if it fit right off the bat.. I'm curious..
Dallas J
Feb 4, 2017 08:12 AM
mak1000
Sep 26, 2015 07:36 PM
john blaze
10
Apr 4, 2010 04:57 PM
JDMevoBOOST
287
Dec 11, 2009 12:02 AM
MayhemSi
Jan 5, 2005 09:57 PM
