lots of boost and race gas ?
Old Apr 15, 2007 | 03:20 PM
fastassfourdoor's Avatar
with a 35 r and rods and pistons. My question is how much psi can u boost without running race fuel......Im just wondering because it seems like i cant run to much psi because it cant be combusted....but i could have sworn i have seen evos running like 500 horses on pump gas....can some one explain this to me...
Old Apr 15, 2007 | 03:26 PM
ThEHiTMaN's Avatar
To my knowledge on straight 93 you can run 21-23 psi. Anything over that would require meth or race gas.
Old Apr 15, 2007 | 03:31 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
The amount of boost you can run will be limited by the octane of the fuel. That being said, there are different ideas as to how to maximize power with different combinations of fuel, timing and boost. With the big turbo, I would run less timing so that I could run the maximum boost my fuel would allow. Search and you'll find some guys running 25 psi or so on 93 or 94.
Old Apr 15, 2007 | 03:34 PM
oh ok so even on bigger turbos than stock people are still runnin 23 psi tops without race gas....because im shootin for 500 on pump with 35 r pistons and rods....possible?
Old Apr 15, 2007 | 04:18 PM
KartaRailed's Avatar
Not on that turbo without methanol. Not easily anyway.
Old Apr 15, 2007 | 04:21 PM
evovin's Avatar
what about stock 16g turbo? can i raise up the boost by just using 110 octane without tune?
Old Apr 15, 2007 | 04:40 PM
chaotichoax's Avatar
yes, assuming you have a boost controller
coolguyuno1
May 16, 2009 12:14 PM
TonyG
Jun 4, 2008 03:16 PM
gt420hp
12
Sep 30, 2007 12:06 AM
drewblueeye
Aug 8, 2007 05:43 AM
Warrtalon
85
Nov 5, 2005 07:52 AM
