Fuel Pressure Regulator Install?
Old Apr 18, 2007 | 12:57 PM
jdmrally's Avatar
Does anyone know or have any instructions on how to install a Fuel Pressure Regulator. Iv'e looked but I just cant find any. thanks for the help.
Old Apr 18, 2007 | 03:57 PM
C6C6CH3vo's Avatar
Cant be too bad,
remove regulator bolts
remove regulator
take smoke break
wipe up gas
install regulator
install regulator bolts
torque them to spec with the value posted in the "how to" section or FS manual purchaced at ebay for $8
Old Apr 18, 2007 | 04:06 PM
dubbleugly01's Avatar
stock or aftermarket?
The install will depend on what regulator you get, what fittings you have, etc.
I just installed an adjustable setup from AMS, and it's straight forward if you have all the needed parts.
Old Apr 18, 2007 | 04:08 PM
blockhed79's Avatar
useless mod
Old Apr 18, 2007 | 04:12 PM
iTune's Avatar
not useless if you are planning on going with a very big set of injectors. Having adjustable static fuel pressure is good tuning tool, when the set-up calls for it.
CJ
Old Apr 18, 2007 | 05:24 PM
Originally Posted by blockhed79
useless mod
depends on your level of mods.
Old Apr 18, 2007 | 07:01 PM
jdmrally's Avatar
Fully Built motor, head, upgraded turbo kit, fuel system etc. its like 450hp. The last thing i need to do is upgrade the Fuel Pressure regulator. I just dont know how to do it. i wasn't the one the took it off so i dont know where it goes. do I use all three ports??
Old Apr 18, 2007 | 07:05 PM
It sounds like you have an aftermarket, adjustable fuel pressure regulator if you have three ports. No, you don't need to use all 3. You should have two side entry ports, and one port at the bottom of the regulator, and an 1/8" NPT port for a gauge. You only need to use one side port, and plug the other. Fuel from the rail goes into a side port, and out the bottom port to your fuel return hose that goes back to the fuel tank.
Old Apr 18, 2007 | 07:13 PM
jdmrally's Avatar
Yeah Its an aeromotive FPR thanks for the help
Old Apr 18, 2007 | 07:52 PM
jdmrally's Avatar
Is this right?
Sorry if im way off
Old Apr 18, 2007 | 08:08 PM
yes, that's right basically. But looking from the front of the Evo at the engine bay, your supply and return are on the wrong ends of the rail. The Evo rail is supplied on the drivers side, and the return is on the passenger side.
Check out this link to a pic of AMS's setup. Hopefully it will give you some orientation on how it's hooked up, use the white handled oil dipstick as a reference point. It's a different regulator, but basically identical to the Aeromotive
http://www.amsperformance.com/store/...n_DSC04937.JPG
Old Apr 18, 2007 | 08:12 PM
ak47po's Avatar
Screen01.jpg?t=1176952309
capture2-6.jpg?t=1176952544
Old Apr 18, 2007 | 08:13 PM
jdmrally's Avatar
Ahh that makes so much more sense now!!! Thanks! :-)
Old Apr 19, 2007 | 09:13 AM
jdmrally's Avatar
What does the little guy on the top half do?
Old Apr 19, 2007 | 09:30 AM
EvoIXJDM's Avatar
Hi, that is the connector for the vacuum line.
