oil leak. need help!
Old Apr 23, 2007 | 06:51 AM
EVOIX2NV's Avatar
got my cams installed couple of months ago and now i have a leak is this an easy fix?do i need a special tool or do i have to bring it to a shop? any help would be great thanks
Old Apr 23, 2007 | 06:53 AM
MRadjahoe's Avatar
If a shop installed them you need to take it back ASAP. There is some sort of seal that isnt tight or is broken
Old Apr 23, 2007 | 07:02 AM
EVOIX2NV's Avatar
yeah i know it sucks but i'm just hoping its only the cam seals.
Old Apr 23, 2007 | 07:12 AM
Daniel_4g63's Avatar
where did you get them intalled? just take it back there its the obvious solution
Old Apr 23, 2007 | 07:27 AM
EVOIX2NV's Avatar
i just checked it again and the bolt that holds the cam sprocket has a small line/crack on it. the oil is coming out from the bolt. its really weird. i guess i have to go to the dealer and order the part as you can see in the pic there's a small puddle of oil on the bolt
Old Apr 23, 2007 | 01:03 PM
scottatyamaha's Avatar
They probably over tightened that bolt. I just did cams on my friends nine and there was not that much tq on it.
Old Apr 23, 2007 | 01:35 PM
EVOIX2NV's Avatar
i just went to dealer and ordered the part. what size hex key do i need when i change the bolt? is it 14mm? and also is it hard to change it and do i need a special tool to do it.. let me know thanks
Old Apr 23, 2007 | 04:16 PM
^ it is a 14mm and no it is not that hard to change if it was tq to the right setting. If it is too tight you will need someone else there to put a wrench on the crank pulley to keep the engine from turning over when you try to break the 14mm hex head loose. When you do get it broke free there will be some oil to come out so have a towel ready to wipe it up so it does not get all over your timing belt.
Old Apr 23, 2007 | 04:53 PM
EVOIX2NV's Avatar
i'm picking the part tomorrow so hopefully everything will work out fine thanks again for everything
EvoIIIAj
May 4, 2009 12:05 AM
AWDBus
Jul 15, 2008 10:46 AM
EVOIX2NV
13
Jan 28, 2008 10:50 AM
EVOIX2NV
Northeast Region
Aug 3, 2007 03:26 PM
ARVSHOP
Jun 8, 2005 10:41 PM
