fp green dyno today.
Old Apr 24, 2007 | 02:46 PM
evo3matt's Avatar
Well my car made 405hp/405 trq @ 28psi on pump and meth today on topspeeds dyno.
Mods - Revolver Cams, crower springs/retainers, Findanza Cam gears, Ported intake manifold 65mm tb, niesi hard pipes and competition fmic, full race manifold, 3" turbo back, invidia o2 housing, aem w/ 3.5 map, 1000cc injectors, smc meth kit
honestly i'm slightly disappointed... and may be switching cams soon, feel free to post. Track this weekend, car feels good though.
on a side note, thank you doug! you're the man =]
Old Apr 24, 2007 | 02:48 PM
shivaswrath's Avatar
GSC cams!!!
Soon2BEVO's Avatar
Is topspeed a Dynojet? Ah it is. Well this is about the 3rd person Ive seen with Revolvers make low power. Id switch them out and I bet u make a ton more. I mean... bloched79 made 400awhp on pump gas at Turbotrix, then switched to Revolvers and went to Buschur and put down the lowest Green numbers ever dynoed there.... that should tell u something.
Old Apr 24, 2007 | 02:49 PM
jhanksevo's Avatar
thats it very low its a dynojet right?
Old Apr 24, 2007 | 02:51 PM
nigletsyz's Avatar
it would have been nice to see these numbers on just pump, no meth. Maybe 450 with meth.
either way, I'm sure your car is fun to drive.
Old Apr 24, 2007 | 02:54 PM
evo3matt's Avatar
it is really fun to drive, pulls good, just don't know where the power is except the revolver myth, they seem to be hit or miss
Old Apr 24, 2007 | 02:55 PM
Soon2BEVO's Avatar
Im tellin you. its them. They are evil or great.
Old Apr 24, 2007 | 02:59 PM
MR. Birdie's Avatar
I'm running the GSC S1 cams on my Green Turbo. No high boost dyno yet =P
Old Apr 24, 2007 | 03:19 PM
Soon2BEVO's Avatar
Youre a great example of the power of the Green. 380whp, on 91 octane off all things with moderate boost. If this guy is only making 20whp more with 6+psi more boost and all the extra timing associated with running meth something is definitely not right. Also, that guy FastFrank made 460whp on 31psi with stock manifold and 02. So Id definitely check out the setup. Boost leaks, knock? Something.
Old Apr 24, 2007 | 03:22 PM
Ev0ikon's Avatar
I remember last year a guy made like 30ft lb more than your car and he was on stock 03 turbo. Same dyno/Topspeed in GA. HKS272/272+93octane+Meth+Dynoflash.
Old Apr 24, 2007 | 03:33 PM
MR. Birdie's Avatar
Yeah serious FastFrank set up is crazy! He can def. hit 500whp on C-16 with 33psi and intake manifold with 65mm TB. * crossing fingers, i'll be back to the dyno with upgrade actuator and high boost run on C-16 gas! *
Old Apr 24, 2007 | 04:48 PM
Aby@MIL.SPEC's Avatar
did you dyno the car on the 16g with all the other mods? if so, how did it do?
unfortunately i agree with your assesment of your numbers w/mods.
what cams are you thinking about?
Old Apr 24, 2007 | 04:56 PM
Fast Frank's Avatar
Cams seem to be hurting it?-272's seem to work best w/ the green
WOT-nice comparison of TB I have been looking for that info-Guesses at difference @460+hp??
Old Apr 24, 2007 | 05:00 PM
UCB's Avatar
UCB
Its not like he's holding 28psi at redline though
Old Apr 24, 2007 | 05:22 PM
Soon2BEVO's Avatar
Who cares
My stock turbo dropped to 19psi and I went 118mph on pump gas. Theres other members that hold more boost to redline and dont go as fast
