4g64.....help
Old Apr 28, 2007 | 01:25 PM
diablo2184's Avatar
4g64.....help
I got a friend 4g64 out of an '00 Eclipse.....it has a spun bearing and scarred crankshaft, is there anything that he can use out of this motor?
Old May 11, 2007 | 11:22 AM
diablo2184's Avatar
anyone? should he just discard of the motor?
Old May 11, 2007 | 11:24 AM
sonicnofadz's Avatar
YES! Don't discard it, give it to me! If he replaces the crank and bearings it should be just fine (as long as it didn't get a hole punched through it by one of the connecting rods!). If the crankshaft journal bearing surface isn't damaged too badly, it might be able to be re-used if the machine shop re-grinds it.
Old Jun 16, 2007 | 05:47 PM
diablo2184's Avatar
oh alright, thanks! i will let him know. if he gets rid of it, i might even think about gettin it......but its his motor, so we'll see.
i dont even know if i would go 2.4 though.....i like my 2.0
Old Jun 17, 2007 | 12:05 PM
diablo2184's Avatar
after reading some of the threads about the 4g64 and Evo head, it seems like the 2000 Eclipse motor doesnt bolt right into the Evo.....is this correct? becuase of engine mounts, p/s and a/c mounts?
and would it be better to use a Lancer Ralliart 2.4L motor instead? if so, how much do one of those go for?
Old Jun 17, 2007 | 01:47 PM
RyuEvoIX's Avatar
The 4g64/4g63 blocks are directly interchangeable between the 3rd Generation Eclipse and the Evo. Reason being I know of atleast 1 3G Eclipse owner that has done a 4g63 swap into an Rs/Gs.
Old Jun 17, 2007 | 01:50 PM
diablo2184's Avatar
ok cool thanks....so no custom mounts or anything?
Old Jun 17, 2007 | 01:58 PM
RyuEvoIX's Avatar
No custom mounts are required.
Old Jun 18, 2007 | 02:59 PM
diablo2184's Avatar
what is the largest that the 4g64 can be bored to?
Old Jun 18, 2007 | 03:07 PM
migueralliart's Avatar
I believe it has 6mm of material from wall to wall between pistons
Old Jun 18, 2007 | 03:13 PM
diablo2184's Avatar
so what would that be in size? like total?
What shop would be willing to help me with this stuff because I just called Road Race Engineering and I talked to someone who was a real dick....I forget his name, but I wanna say Robert. He was just trying to get me off the phone and I am trying to understand the 2.4L setup......but was no help.
Old Jun 18, 2007 | 10:45 PM
RyuEvoIX's Avatar
I wouldn't have the 4g64 block bored out anymore then .040 over personally.
Old Jun 19, 2007 | 08:23 AM
Benz04GSR's Avatar
Hell, I have a 3G eclipse, and am doing the opposite this winter (Evo Head on top of my block.)
It'll make your car a 2.3, not a 2.4. It's much easier to start on your side, as you already have most of the parts you need right in your engine bay. Also, if you're gonna spend the money, get the RRS Pistons made for a 4G63/4G64 Hybrid motor... with their rings, you'll get 8:1 compression and be able to get boost happy.
If you're interested in the swap, join Club3G.com and talk to a couple guys in there, it's a popular swap. DNS-EN, FlashBlueRS or NAPALM are probably the best people on the site to talk to about the hybrid.
Aniel
Feb 13, 2016 02:21 AM
wesleylawson6
Lancer Engine Tech
Jan 7, 2015 05:27 PM
Evo3573
22
Dec 26, 2014 07:32 PM
PHILLY EVO
Mar 7, 2009 08:43 AM
SeanC
Nov 27, 2007 03:21 PM
